Do you know if there is a way to buy the piece made from a trustworthy manufacturer ? It seems like the following bike have the same piece, however I only find seatpost/saddle combos :
If you’re sure it’s the same as cervelo, they make the seat post head for sp18-20 (bike inn has it in stock… But not sure if it’s really the exact same)
Yes, those are ritchey clamps, so should be able to just buy that clamp and contacting Ritchey directly is pretty easy, too. If you have trouble, reply here and I can ping folks over there.
I think the p3 was a ritchie logic bolt (not sure which part “broke” though, the part that connected to the seatpost, or the top piece)
No, its the bottom part, that attaches to the top part you mentioned to the actual seatpost, I drew in blue the part that failed (both front and rear of the rail, it actually doesn’t move but seems unsafe as f**k :
looks like the above part is made by ritchey, but not the one that failed
It would mean buying the whole post, but would one of these work?
Scott - Plasma TT HMX5 - Seatpost - Gloss – CYKOM
Syncros - Plasma TT Carbon Seatpost - Gloss – CYKOM
My old Plasma 5 is sitting in storage at the moment.
Can you clarify which exact part has failed? Is it the actual seat post section which the bolts mount into, or the receivers which are in the tube in the seat post, or is it the actual carbon part of the seat post where that tube is etc??
The rails etc are all easy to replace, but if the seat post itself if damaged and has failed then that is different and more expensive. Can you post pics of your actual failure?
have you ever bought from them?
I have this bike and spare parts are a nightmare.
I broke my handlebar and got lucky and found one on eBay.
Since then I’ve been sourcing other spare parts. This place has great prices.
Concerning the clamp form eBay, you don have a guarantee and it’s only $40. Worth a shot.
Thats exactly the idea of the topic : It has nothing to do with the seatpost in itself, the clamp is the same for all the bikes I mentioned in the first post, it should be cheap, but I can’t find it anywhere !
I have. Bought a saddle; used but as described and shown in the photos. No issues.
Of cervelo makes the part, you can contact cervelo customer support they will tell you the part number, and from there, you can go to a dealer and get them to order that cervelo part
