I keep my seat nose tilted down quie a bit on my ri bike. On my mountain and road bikes they are both down a bit as well. I was told by someone today that all my bikes fit wrong and that none of the pros do this.
So, if I tilt mine up to level I can’t feel my penis after a while and it puts some odd pressure on my grapes. I was told by the doctor that did my vasectomy that I have a large sack (if only woman were impressed by that)
So the question is, does it matter? I mean I know if you tilt down too low you start feeling like you are sliding off, but I’m not there and I am comfy.
If it is the fit wrong, what part? what fixes that?
In general for a man the nose of the saddle is level w/ the tail when you bike is fit properly (possibly slightly nose down or up). If you do not have a proper bike fit and a seat that works w/ your anatomy, you may find yourself tilting the seat excessively down. If tilting the seat down is not causing you any issues, than I would not worry too much about it. However, a large degree of nose down will cause you to move forward on the saddle and you will find yourself holding back w/ your arms. this may cause other issues.
what someone told you is generally correct. a good saddle that is comfortable for you and fits your anatomy should be nearly level, not substantially tilted up or down, even on a tri bike. and yes, no fast pros’ bikes that i have seen have a significantly tilted up/down saddle.
and nearly all the other people i have seen riding with a highly tilted down saddle were correcting for another common problem: their saddle was way too high. if you are getting pain with a level saddle, you need to address some other fit issues. often (but not always), you need to lower your saddle, get a different saddle, or both …
I would like to add that it is quite often necessary to rotate the saddle to the right or left slightly. This will be a little bit of trial and error but there will be a noticable change in comfort when the rotation is on the right side.This will move the crotch pressure to the adductor muscles and they are much more tolerant of the pressures. I suggest level for the seat to slightly nose high combined with rotation. A downward tilted nose puts a lot of pressure on the neck and shoulders.
I agree…all of my saddles are rotated to the right about 3/4 - 1 inch (off of center line of the top tube). Makes a huge difference in comfort. Plus, it reduces the probability that my sack o’ grapes will hurt and my penis will go numb.
