Saddle Bottle Cage with Garmin Varia Mount
Hi all,
I’m currently using a 2019 Trek Speed Concept that has the draft box.
I want to put one of those rear saddle double bottle cages.
Does anyone know of any that also has extra railings or place to put a Garmin Varia on the back of it as well?
Thank you so much
This should fit the bill, with a little work.
https://sportrhino.com/products/bike-seat-water-bottle-cage-holder-led-light-rear-hydration-triathlon-bottle-cage-holder-does-not-include-bottle-cages-or-co2-as-pictured?variant_id=569797
I have and Xlab Super wing and I attached the computer mount that came with my front mount Torpedo to the rear of that. Works awesome!
Find a seat bottle cage frame that holes in the back surface. Then bolt a stem Garmin computer mount there. i.e., a circular Garmin mount that is meant for installing a Garmin computer on top of the bike stem.
I use an Xlab that connects to the seat rails and have a 3d printed garmin mount for me aero seat post. Its perfect.
I tried lots of things - including zip ties and lots of electrical tape connected to the back of an X-lab turbo - and I landed on using the X-lab super wing. That’s the solid piece rear bottle carrier (the turbo wing is two pieces, one for each side). Yes, I bought the super wing JUST for the ability to mount the darn Radar. The super wing has a solid back with holes in it - and those holes are perfect for mounting a garmin mount. It is really secure and holds the radar at an appropriate angle. That’s what I have done because I am short and I literally have zero room under the rear bottle cages to mount anything. I can’t speak to the new Varia because it has a different mount, but looking at it - it should work just fine too.
I use a top cap Garmin Mount on the back of the bontrager rear cage. It works but is hard to get off.with a cage or 2 mounted. I just leave it on and charge like that.
I have also put it on the seatpost with the rubber mount
I got a Garmin spoon mount. Then drilled extra holes as needed to line up with the water bottle cage holes. Used different length bolts and rubber bushing as necessary. Has worked great. On 1 bike I have lined up vertically. On another I did it horizontally. Clean and works great. I also superglued a camera lens cap strap I hook on the cage so if were to get knocked off still have it.
Barb L
