S60 and s80 valve length
Does anyone know what tube valve length you need for s60 and s80. I am borrowing the wheels so valve extenders are not really something I am interested in.
I use 80mm valves in my S60 wheels.
Do you know if 60s work?
The depth of the S60s is 60mm, so a 60mm valve won’t be long enough. With the 80mm valve, 20mm is sticking through for you to blow up the tires. If you are going with 60mm valves, then get valve extenders.
so even with a 80mm valve on the s80s i will also need a valve extender?
Yes
The wheels were supplied with extenders so I’d ask if you can borrow the extenders too. They are simple to use if that’s your worry.
