I used to be a triathlete and have done 7-8 halves and one full.
Normally between 5:30 and 5:45 for a half, but I have not done a triathlon for 5 years.
I have just been finding my groove with some running and looking to add in some cycling shortly, but I was wondering what sort of weekly volume would be recommended running wise if training for a half. I know it will vary per person and with a lot of other factors but any rough guidelines would be great.
The plan is to get run volume where it needs to be before adding the other disciplines but not sure where I should draw that line!
I came to tri from a running/marathon background, and expectedly favored run volume over bike at first, and gradually shifted to the more typical bike over run volume for a balanced triathlon plan.
I’ve since def become slower in standalone running races, and not just because of age - I was definitely faster as a pure runner on less training hours per week, than as a triathlete with more training hours (but less total run hours), luckily not by a huge amount though.
After about 10 years of doing this sport, I’ve finally made the full transition to my identity as a triathlete, rather than a runner that does tri, which means I’ve embraced the swim, accepted and now trust training plans that emphasize the bike, and am ok with running a ‘mere’ 25-30mpw (30mpw max).
What I’ve found as a result, is that my triathlon run (Oly and HIM) has continued to improve over these past 10 years, with my best result coming in my most recent race where I ran almost the least that I’ve ever run for a successful training block. (Oly in this case). No runs over 90 minutes for Oly training, and max mpw 28.5 in my case, with average closer to 25. I’m now convinced that the good tri training plans, which typically emphasize the bike, are doing it right.
Note that I’m not saying I’m a better pure runner now than I was when I was doing only running events. That’s definitely NOT true. I was absolutely a better pure runner back when I was only doing running and running more volume as a result. But triathlon is about swim-bike-run, and the reality is that most AGers drastically underappreciate the impact that the swim (especially!) and the bike have on their run legs. In fact, the biggest difference I’m sure that I made in getting my best run result was swimming more and building strong swim resilience. (I took cycling seriously too but was already cycling enough, so that didn’t change much.) And on race day, I actually had a lousy swim time given my fitness - followed some swimmers off to a middle buoy that drifted off course, and realized too late that everyone else was just skipping this errant buoy and going right for the next one without the detour, so didn’t remotely swim a PR. But the swim took so little out of me relatively that I could bike well, and then drop a run that was solid - solid enough that I nearly outran my training partner who swam literally 1/3rd the amount I did (which was still 3-4k/wk) and who outran me in every training run by nearly 45sec/mile on Strava.
Long story short, 25-30mpw should be good for Oly and even HIM events (maybe slightly more for HIM events), but just as important to that is sufficient fitness and training on the swim and the bike. I’m convinced now that what the ST experts saying is right - the run isn’t really all about your running ability, it’s equally about your swim and bike fitness, and that more running won’t help you as much if you don’t have those two pieces sufficiently trained.
