Does this make sense?
If you have an inefficiency, you want to minimize the amount and/or frequency at which you repeat the inefficiency in order to be more efficient. Unless, of course, a particular inefficiency is a minor byproduct of some action that is more efficient for the specific task at hand. There are several kinds of inefficiencies taking place in a pedal stroke, some of which may be more important to eliminate than others (I suspect that the importance of elimination of specific inefficiencies may vary from subject to subject…not everyone has the same limitations/physiology.kinesiology). I think that some of the inefficiencies are more important to eliminate depending upon whether you are in a sprint effort or a time trial, or a sprint triathlon compared to an Ironman distance.
I’m also certain that NO level of current physics knowledge is sufficient to be able to put all of the nuances of a pedal stroke into a formula that works to determine efficiency for any individual, much less a group of individuals. There are too many variables which affect efficiency…blood flow, blood pressure, capillary density, hemoglobin level, glycogen level in the muscle, hormones present/absent, mental status, motivational status, previous/current training regimen, mitochondrial efficiency/numbers, oxygenation level, crankarm length, angle of the seatpost, tightness of the cycling shoe, variation from one pedal stroke to the next, etc.
From a practical point of view, it seems that the “best” running stride rate for an individual may coincide roughly with their “most efficient” cycling cadence. The faster striding runners seem to do better (meaning higher average speed for a sustainable time) with higher biking cadences, and slower striders do better with lower biking cadences. Personally, when running at my “best” sustainable speed, I have a stride rate in the lower-mid 80’s. (“Best” is defined as the point where when I slow the stride rate my speed drops, but whenn I raise the stride rate my Heart-rate rises significantly with no real increase in speed.) My best cadence on a bike seems to be slightly slower, at least for up to 1/2 ironman distances. I have no experience in Ironman distances.
I fought going to the lower cadence for a long time, thinking a higher biking cadence was better due to my road racing background. I found higher cadence worked great for road racing (I have never lost a field sprint), but I found I’m faster at lower cadences in time trials, and triathlons.
I wonder if this stride rate/bike cadence relationship is a truism across a wide range of subjects, or if I think I’m noticing something that isn’t actually true.
aka Ktalon
