Rotorcranks installation question
'got it! I finally received this morning a magnificent set of titanium RS4 (square spindle) 54 x 44. I cannot wait to install them on my bike. They look so mean that I’d better work on my engine if I do not want to look ridiculous ;-).
Yes I am a poser but I have some pride too…
I installed my durace cranks by myself, the downloadable installation manual looks clear enough, so I figure that I should be able to install it by myself with a little extra attention.
The only thing is I noticed on Gary’s website that I should use a primer with my titanium frame. So far i only have a tube of blue loctite.
What is the primer for? Is is only intended to clean the threads of the BB, or shall I use some INSTEAD of blue loctite?
Can I find some here in Europe, and if so what primer should I use?
And yes, I will have a hard time looking at the bike (and not riding it) for three days to let it cure…
can put you in touch with the UK Rotor distributor if you like. Would that help?
I think the primer allows the locktite to cure faster…important for Titanium.
You don’t really need to use the Loctite primer for a Ti or Mg frame, unless you cannot get the Loctite to cure the first time
Any blue colored thread locker should work, especially if you give it some extended time to set, use a thin layer
Most importantly, torque the left cup tight, to 55 lbs as instructed in the manual.
Enjoy riding your set of Rotors!
Gary Tingley - RotorCranks.com
Thank you Guys for your input. I appreciate it.
Gary, I will try and get away with Blue loctite only, and let it cure for three days (I’ll have to be very patient!)… hope it works. Thanks for your advice. I shall give you some feedback as I start adapting to the RCs.
Can’t wait though, I tried osymetric chainrings last winter, they were a blast, but have far too much ovality (around 22%) for them to work without putting too much strain on the drivetrain… hence the RCs (first time I am happy to put extra weight on my bike :wink: ).
It may not take three days, try two
  • Gary
Well, this would be a relief!! Thanks, I’ll try.
Gary,
Is the 2-3 day wait because it is a titanium frame? I only waited about 16-18 hours (overnight). Mine are installed on Zipp frames with the aluminum bb shell.
When I get my velotron in 2 weeks, this “toy” will break my bank.
Dave
Hello,
What do you mean by too much strain on the drivetrain? Also you said tat you liked them, any numbers on how much improvement they made?
Thanks, Styrrell
Hi,
Well, I found they work for me: no numbers, for I used them in the off season. But they felt very good, especially on the climbs. I noticed that, when getting out of the saddle, my heart rate did not gain a few bpm as it does with round chainrings, but stayed level. My pedal stroke felt far “rounder” than on round rings, I could feel that power was more evenly distributed over the pedal stroke… very nice feeling indeed.
But I know some will call me lazy and tell me to go fixie, try track racing or by PCs (which I would buy on the spot if I had the dough and a second bike, though, as I started single-leg drills one weeks ago: makes sooo much sense).
The downside is, from a mechanical standpoint I got a few problems: the first set of rings wore off in less than 1000 km. I got it replaced for free and installed them back on my bike, but I then experienced heavy chain skipping (new cogset AND new chain, go figure): my LBS tried everything he could (tightened the rear derailleur, shortened the chain, lubed the under bottom bracket cable guide, etc… to no avail.
I am still baffled at this as the first set of rings worked fine at least for the first 1000 kms…
Nevermind, I think that less ovalized chainrings (Eggrings, Q-rings) shall be a better option from a mechanical standpoint. Plus I had been drooling on RCs-equipped bikes for quite some time, so i took the plunge and bought rotorcranks… we’ll see how it goes.
Any news on the “Q-rings”?
Like how they work compared to reg. rotors?
Yes, the thread locker dries slower on Ti, for most applications
