Rotor Q-rings have 5 positions to select the installation position. 3 is meant to be the default position for road bikes, 4 on TT bikes (due more vertical seat post).
Ridea has only one position, and on Rotor scale, this would mean either -1 or -2.
This means that the “power phase” in Ridea gear comes much earlier than in Rotor Q-ring gear, and also goes away much earlier.
When pedalling on Ridea I clearly felt this, the “easy gear” starts too early.
This difference is this position is much bigger difference than anything on the details of the oval forms has effect.
Then my own experience on power output:
2013-2014 I used Q-rings on some races.
On Winter 2015 I did lots of training on trainer during the winter with q-rings, and got nice improvements on my power output.
I switched to Ridea during May. I also reduced the amount of my indoor trainer exercise and did more exercise outside, without power meter.
On june I noticed I’m not practically at all faster with the Rideas that I was during 2013 and 2014 with Q-rings even though I had clear power output improvements during the winter due my trainer workouts. On may I was only couple of seconds faster on my own 26.6 km tempo test ride than I had been on 2013.
I did some trainer sessions to confirm this, there were interval sets I used to do with 320 watts with q-rings on april and on july I could not finish there with 310 watts in Ridea.
So, I decided to switch back to Q-rings, but do a tempo ride before and after the test.
So yesterday I did my last ride with the Rideas. Again the same 26.6 km tempo, time 45:33, average speed 35.0 km/h, average heartbeat 164.
This was over half minute faster than on May, so even though I was doing worse on trainer with ridea at July than I did on trainer with Q-rings on April,
my power output from may to august had improved.
Today morning I switched the big gear back to Q-ring, and did the same tempo ride again. Same route. Time 45:08, average speed 35.3km/h, average heartbeat 168.
And the wind was worse today and I had to waste few second at one intersection due car traffic.
So, 0.9% difference in speed between the rides on two consecutive days by switching the big gear from Ridea to Q-rings.
This should mean some 2-3% difference in power.
It seems that with Q-rings my anaerobic threshold gets higher (on both power and heartbear), I can pedal harder without lactatic acid killing my muscles.
So, to me it seems the Ridea guys messed up by having the bolt holes in wrong place in their gears. No hype about double-ovality helps when the double-ovality kicks in way too early and gives up way too early.
