Hi I run a 50t q ring, as you turn the cranks the 50 becomes a 53 at the downstroke then gets less on the upstroke, ive used it for everything tris to time trials, ive no intention of changing as I like them
" A 50T Q-Ring, around the upper dead-spot is equivalent to a 48T, but as the pedal goes down and more strength is applied, the equivalent chainring tooth size reaches 52T."
“A 53T Q-Ring, around the upper dead-spot is equivalent to a 51T, but as the pedal goes down and more strength is applied, the equivalent chainring tooth size reaches 56T.”
I find that a 53t q ring feels ‘bigger’ than a 53t round ring. So if you’re riding a round 53t and wanna try q rings, I’d go for a 52, maybe even a 50.
I would go with a 50. It’s plenty big at the large diameter (roughly a 53), yet small enough to push the gear at the smallest. I’ve tried a 52 Q-ring and it feels larger than a 53 round.
I have a compact Cannondale Quarq powermeter. I obtained the Rotor 50T ring but was unable to install it on my Cannondale cranks due to the design of the powermeter. I had no problem in returning the Rotor rings for a refund and notified Quarq of the design issue with rotor rings. I hope yours work well.
