my rock shox judy air fork is bottoming out and i was wondering if you can put air into it and how. thanks.
hmm, Judy is a pretty old fork. better place to look is www.mtbr.com, lots of tuning tips there
which model fork do you have, the only judy (2002 xc) I have experience with, had a cap on the left leg, unscrew this and there’s a kind of air valve that needs a needle adaptor like you would use to inflate a basketball. 50psi is the maximum pressure here.
the judys didn’t hold their air all that well so it needs to be checked regularly.
As someone else said, it depends on which Judy model you have. The Judy was in production for about a hundred years, with 30 or 40 different versions/models. I second looking it up…
