Weird thing going on with tubeless setup (first time road tubeless, many years of cross and mtb tubeless).
Rims are Kinlin XR-26T, tires are Conti GP5000 (both tubeless variants of course, nothing hacky here).
When I threw the tires on, they went on firmly with levers, nothing ridiculous but nothing I could do with my thumbs alone, so that felt normal to me. Inflated with an air compressor, didn’t hear the bead pop, so took the core out of the valve, and then inflated again, and that time I heard one snap, but not two. Took compressor off the valve, all air came out, and sure enough, one bead collapsed in once there was no pressure in there. But the other side was still on there.
Put core back in the Presta valve, and inflated, same thing, tire LOOKED fine, but never heard another snap. Took compressor off, and tire holds air. Weird. Did the next wheel, same exact thing happens.
I overinflated them both to maybe 100psi and left them for the night in the garage. Checked this morning, both were holding air. Thumb check had them both still at a pressure I could ride on too, but they did lose air overnight as I haven’t put in sealant yet.
Deflated them both, and sure enough, one bead slides off when fully deflated.
Inflated again, and holding air again. Checking around the bead, there is nothing indicating to me that it isn’t on the rim securely, sometimes you can sorta see the tire where it hasn’t snapped into place, these are perfectly round, no issues.
Used soapy water too, to see if it would matter, it didn’t. It just seems like when deflated, that the tires won’t stay on the rim, which has never been something I’ve had happen. MTB and CX tires stay on even when flat.
I’d feel mildly better if the beads were locked on there like I’ve experienced before, but with them holding air and not being deformed, I’m not sure what to think.
Any experience with this type of thing?
Thanks all.
