I too have been bottom to top with figure 8 around the hoods. My go to is the Park Tools info most often to remind me the procedure. I just retaped my handle bars this past weekend.
Agreed - pretty much everyone, for good reason, says, for road handle bars go bottom of the the drops to top.
Many great videos of How To online, but I agree for many things do-it-your-self for bikes, the Park Tool vids are awesome!
I’m a big fan of the Fizik Microtex Bar tape. I always use white tape (to match my white saddle - you know The Rules!), and the Fizik tape always stays clean and white. It just needs a little bit of a wash down every now and then with Simple Green, and it can stay looking new - all season long.
I use the basic bottom to top technique, and what I do for customization, is where my hands rest some times - just behind the rubber boot of the shifter/brake unit, I do about 5 - 8 cm of a double rap underneath. This adds some extra padding and a slight bit of thickness.
Silca launched last year a line of bar tapes, that I’m interested in trying. They use a thin film of padding that is similar to the compound used in the Nike Vaporfly shoes - that is reported to add no bulk, but dramatically increase comfort to bar tape!
Contact points with the bike are key to comfort. And comfort is key to spending time on the bike. And spending time on the bike is a key to fitness.
The only advantage that I’m aware of going bottom to top is that the edges are less likely to curl (on certain tapes, not all)
Going top to bottom eliminates that ugly finishing strip and (in theory) maintains more tension on the tape so it’s less likely to unravel itself if you use stuff that doesn’t have strong adhesive.
I’ll see how it holds up over the next few weeks.
