This is my first time ever taking a test, and probably the last one I will for a while (uni student and it was for a study) so I don’t know what it all means. First thing that came to note is that it took too long to ramp up to a decent pace and actually stress me. I was hoping someone would be able to give me some insight into how I should structure track workouts with this new information. Goals are to put down a respectable (sub 40 minute) 10k in a flat olympic, or a 42ish at Wildflower. 6’ tall and 165 lbs (155lb goal for race season)
Thanks in advance!
Daniel
Test Protocol: Treadmill test
Started out very slowly and built up to a comfortable point of 8.2 mph at a 3% grade (8th minute) by ramping in .5 mph gradations. I functionally consider the first 5 minutes warmup and the 3 minutes thereafter a brisk but maintainable pace. In addition to the ones labelled, I have METS and REE if you’re really curious, or it’s critical to the analysis. Steepness and speed were added on the minute start.
Time-HR-VO2(L/min)-VO2/kg (ml/(kg*min))-RER-Speed-Grade %
8:01 159 3.87 52.0 .95 8.2 3
8:30 143 4.07 54.7 .98 8.2 3.9
9:00 165 4.09 55.0 1.00 8.2 4
9:31 155 4.16 55.9 .99 8.2 5.4
10:00 168 4.27 57.4 1.01 8.2 5.5
10:30 171 4.44 59.7 1.01 8.2 6.8
11:00 174 4.53 60.8 1.02 8.2 7
11:30 177 4.68 62.9 1.04 8.2 8.4
12:01 180 4.83 64.8 1.08 8.2 8.5
12:30 182 5.04 67.7 1.11 8.2 9.8
13:00 184 5.01 67.2 1.12 8.2 10
13:32 186 5.17 69.5 1.15 8.6 10
14:00 186 4.59 61.6 1.19 7.8 5.6
14:30 174 3.54 47.6 1.33 3.1 0
15:01 156 2.94 39.4 1.40 4.9 0
15:30 147 3.05 41.0 1.25 5.9 0
16:00 141 3.05 41.0 1.15 5.5 0
Questions: What does MET, RER, and REE mean? I noted that my heart rate recovery was rather slow, is it a function of me not completely stopping, but slowing down a ton, but still shuffling? What can I meaningfully draw from this information? I made it comfortably up to the max steepness at 8.2 mph, but the second the tech brought the speed up to 8.6mph, I cracked… why is that so?
Thanks again,
