REPLACEMENT: Aerus Biospeed Bike Travel Case
Hi,
it seems that the most popular bike case in our triathlon world is discontinueed :frowning:
On www.mpgear.com, they suggest two replacements and I’m wondering if some of you have comment/recommandation about those:
  • Swift Ochrana Bike Bag
  • Mpog Travelspeed Softside Bike Travel Bag (which doesn’t seem available too!!!)
Any other recommandation for a Aerus replacement?
Thanks,
Fred
That swift is an exact copy of the biospeed bag.
they are running a weekend sale… 30% off
There are some minor changes/improvements over the aerus bag but it is the same stealthy size.
http://www.cyclocrossracing.com/item/Ochrana-bike-travel/Swift-Ochrana-Bike-Bag/1.html
Thanks a lot. I just bought one!
Check out the Pika Packworks bags, http://pikapackworks.com.
I have been extremely happy with mine.
Glad it worked out for you
As many of you know i have used this bag for 7+years now. I have taken it EVERYWHERE. Europe, Asia and all over the US.
Great bag.
if you have any questions about it just let me know.
Thanks, just purchased!! I was eyeing this for a while and was planning on purchasing before next season because my 3 main races I am flying to so this sale made me move my purchase plans up a few months.
I will second this as a great bike bag. I have had mine for 7 years now. I have lost track of how many flight legs and miles that case has logged. My ONLY beef is the lack of wheels. Even when I keep it light, the size coupled with weight is awkward, and perhaps more so since I am living life around some neck/head injuries that are now chronic…if this thing could have some wheels it would be golden.
I added wheels to mine. Super easy to do, just a piece of plywood cut to fit in the bottom and caster wheels screwed through the case into the wood at the 4 bottom corners (I reinforced the fabric first). So easy to drag now, but I can still pick it up if needed.
I thought of doing that, but I thought the external wheels would get sheered off. But sounds like you had a positive experience. Maybe I will try that for my next trip!
Dev, please dont add wheels, I plan on borrowing your bag for Kona 2019 and hope to sneak it through a couple more check points (again)!!!
If I did it again I would move the wheels about 3 inches in from the ends of the bags. That wat they are a little more hidden/out of the way and you can still pick up one end and pull it on the other 2 wheels. (I use the strap that cinched on the end as a hadle). It’s also possible to take the wheels off but you’d have the holes in the canvas. And I don’t know why you would. It functions the same and is easier w/ wheels.
Chance,
Will a xl shiv fit in it? Indeed a bag for panama?
Thx
Chance,
Thx
Kaiser,
Well, i am way too short to ride an XL and have not been on a Specialized in a long time so i cant answer for sure…but, i can tell you this. The Wurteles are about as tall as they come in Triathlon and they used this same bag when the Triad was a bike with a seat mast. One of them had to remove the crank to use it but the other didnt.
If you will measure from the bottom of the CHAINRINGS to the top of the seatpost and then measure from the very back edge of your rear wheel to the top of the headtube I will measure the inside of my bag here and let you know what i come up with.
Thanks Chance. 36" on the height. 48" on the diagonal assuming no add on for cockpit.
Agree this is a great bag. I loaned it to a friend and he made up a simple removable set of wheels on a small piece of plywood, held on by bungie cord. You can borrow that if you want Dev. Personally, I only add my helmet and a pump with the bike so keep the bag light enough that it’s easy enough to carry without the wheels.
I assume everyone that uses this bag carries race wheels in it. Being on the outside of the bag I’m very nervous they’ll get damaged from being thrown around. Can someone calm my nerves or give me a solution for this? I also didn’t get the skewers that are supposed to come with the bag. I guess they were out.
We will have the bag back in stock this summer along with some additional bags we are working on.
Anyone?
