Looking for suggestions for a red blinky LED that mounts well on the back of an aero seat post (aero post on a 2011 P3). Don’t need something huge or super bright, just something compact and simple. Thanks.
Knog Cobbler does a nice job.
Looks good, but images online only show a round seatpost mount. They mention an aero post mount, but even with searching I can find no photos of that. Do you have any pics of the back of the light? Do you use it on an aero post?
Make friends with someone with a 3D printer. Design an adapter so you can use any rear light that normally mounts to round seat post.
That’s what I ended up doing and it’s been flawless solution. Can easily mount a regular bike light to the goofy aero shape.
Sure, that is a possibility. But if there is already a great rear light out there with such a mount, I might be good with that. Why reinvent the wheel?
I’ve an Exposure ‘TraceR’ rear light that I swap between bikes, and the aero post adaptor bracket for an aero post (I have the normal round post bracket on the road bike and on a commuter)
Not the cheapest - but a real quality product and Exposure (same Co as make USE components like some aero bars and seat posts) customer service is excellent here in the UK.
I use a Cycliq Fly6 which has an aero seat post adapter. Works flawlessly. I have used it on a Specialized Shiv and a QR PR5. I also use the “regular” post mount on my road & gravel bikes.
That’s fair. Maybe there is something out there for your Cervelo.
But at least in my situation (Trek SC) even the “aero adapters†didn’t work. They’d all get shifted to the side after a few bumps in the road.
Good luck.
That has some potential. But, if you have one, a question: what keeps the light from just popping out of the bracket. It kinda looks precarious, but maybe that is just an illusion:
I do have access to printer. Did you make such an adapter for your SC? If yes, can you post a pic? Might give me some ideas as to how best to approach this …
The cycliq looks nice, but it is super expensive if I just need a small led light, no need for a camera at this time.
I’ve tried a lot of them over the years. This light will meet all the needs you listed: https://www.niterider.com/products/sentry-aero-260-daylight-visible-taillight It comes with a longer strap for use with deep aero seat posts.
The Cycliq lights are a great idea, but their execution leaves a lot to be desired for the cost. Their mounts also suck, though the taillight version is not as bad as the headlight.
I’m a big Garmin Varia fan and their mounts work well. But these are much more costly than a dedicated taillight.
"Looks good, but images online only show a round seatpost mount. "
The Big Cobber is a great light. It DOES come with long bands for an aero seat post. They are really just fancy/better rubber bands that work great.
x2.
I actually have sold the bike, and adapter with it. So don’t have photos. I need to design a new one for the new bike.
But here’s a link to the design file that should give you an idea: https://www.tinkercad.com/things/dTUEirJlJFu
I traced the outline of the seat post, scanned it in as a photo, then used that to trace the shape into a design object. Then I took a circle the diameter of normal seat post, cut that in half, then merged the shapes together. Hopefully that makes sense.
It did take two prints as the first print was a hair too small, so I had to print another at 105%, and it was perfect.
The niterider looks like it has potential, thanks.
Does the cobbler stay pretty well in one place on the back of the post with the longer aero strap?
I follow what you did, a pretty simple and effective solution. Might be worth a try as well.
