Recommend me a good TV mount
I need a new TV mount for the cave. I have a 35" flat screen with standard mounting ports. What I’d like is a wall mount that can be readily vertically adjusted by, perhaps, 24" of play. Sometimes I need it lower, sometimes higher. I’d also like for it to swivel by at least 90º. My googling gives me various products with unreliable reviews.
These may seem expensive, but I have used these on several machines with great success. The use and abuse they see is great and they don’t break. They do have some adjustment or above/below weight limits as they use gas springs for adjustment. But the brand is rock solid.
https://www.ergotron.com/en-us/products/product-details/45-361#?color=polished%20aluminum
They still make 35” TVs? 😁
For a monitor that size, almost anything will work.
No idea. This thing is at least a decade old. Homie ain’t buying no new TV when this one works just fine.
For example, ________ (<-- jim to fill in the blank here)
This looks excellent! and the kind of thing I had in mind but failed to discover.
double check vendor site to see if it works with your older set. I had an old sony and it did not have the mounting points that are now standards.
You realize the mounting bracket you’re going to buy is probably worth more than the TV being mounted to it, right? Just sayin’.
In all seriousness… look at the Sanus mounts they sell at places like Best Buy.
