Quintana Roo's First Gravel Bike Is an OBED in a Tri Suit
Quintana Roo just announced its first-ever gravel bike, the Service Grava, and the press release does its level best to make it sound like a from-scratch act of devotion: the team “took the time to consider the requirements and create a machine worthy of the Quintana Roo name to serve that purpose—then we built one.”
Here’s the thing. The Service Grava is, built on the same frame as the Newer version OBED GVR — Most slowtwitchers understand and know that both brands live under American Bicycle Group in Chattanooga. And if you didn’t.. Well now you know. But most of you already do.. and most of you on this site are way too smart to not figure out the these two bikes share the same frame as the “Chassis” And save you all some time
Here are some quick compare facts.
  • Frame weight: 931 grams, size M, painted, no hardware. Identical on both spec sheets
  • Tire clearance: 56mm / 2.2″ in the rear, up to 61mm / 2.4″ up front. Identical
  • Geometry: longer reach, slacker head angle, and a 53mm fork rake on suspension-corrected geometry. Identical
  • Standards: UDH rear dropout, threaded T47 bottom bracket, three bottle positions inside the main triangle plus top-tube and under-downtube accessory mounts. Identical
  • Even the fork story is the same: “an ultra-wide fork that smooths airflow between the blades and front wheel before it reaches an aero downtube”.
So why put a different brand logo on the same frame? In my opinion.. simple.. Customer awareness and Brand Loyalty. Even though most of this community understands that Litespeed, OBED, and Quintana Roo are all owed and built under the same roof (American Bicycle Group) sadly some people aren’t slowtwitchers “yet”. So understanding someone new to the brand does know that I sure the idea and challenge of sales, marketing and branding of these 3 different brands is something that Christopher Pascarella (President and CEO) of ABG probably thinks a lot about. So now that we know the chassis “Frame” is the same what is different and what are you buying? Mostly, it’s paint options, and branding. Because currently OBED sells the GVR as a gravel race bike, full stop – complete bikes start at $3,998 (currently $4,209 regular), and a frame set is $2,469. QR sells the same frame as “a between-sessions, off-season, technical-handling crossover for triathletes who want out of the aerobars”. Enter the Service Grava starts at $4,549 with Shimano GRX 820 1x and a DT Swiss G1800 Spline 25 DB wheelset. So roughly a $340 premium over the OBED entry point for QR’s color palette and the QR name on the downtube. Is it worth the extra $340 for the right paint and logo? I mean, go ask someone who spends upwards of 60% more for a big “S” 🙂
I was at ABG HQ last fall and I was able to see this frame in person and talk to the whole team about it and the future. I asked the same question over and over again.
I understand why Litespeed is its own brand but I don’t understand the OBED piece anymore. I think ABG makes great bikes and I think the cross over is big enough in our space that combining OBED and QR from a branding perspective would save everyone a lot of headache. Is this what they are finally starting to do? Was I right? I doubt they care that much about my “opinion”, but I will say that during those in person days the included riding bikes the bottom line: I was very excited about seeing this new frame/bike come to market as it is genuinely a good gravel frame — Until like version 1 that is a simple open mold this updated version actually has ABG’s hands all over it. It’s light, big clearance, modern geo standards, and comes with the ABG purchasing process so I was glad to see at least that it’s made its way over so that the QR triathletes who want a one-brand garage now have a clean way to get one and lets be honest “We” triathletes are very brand loyal and we like to match. Just know that the Service Grava and the OBED GVR are, underneath the paint and logo customization, the same bike. If brand loyalty and color options are worth the extra spend to you. If they’re not, OBED’s order page is one ABG website over.
Quintana Roo Service Grava — Spec Sheet
First-ever Quintana Roo gravel bike. Sizes XS–XL. Ordered direct, painted and assembled, shipped worldwide from Chattanooga, TN.
Frame & Fork
Spec Detail
Frame weight 931g ±3% (size M, painted, no hardware); ~886g raw
Material High-modulus carbon, tri/road-derived layup
Bottom bracket Threaded T47
Derailleur hanger UDH (full-mount compatible)
Front derailleur Bolt-on mount
Cable routing Fully integrated
Seatpost diameter 27.2mm
Axle spacing 12×100mm front / 12×142mm rear thru-axle
Max chainring 44t (1x) / 48–31t (2x)
Max rotor 160mm front / 160mm rear
Fork rake 53mm offset; 420mm axle-to-crown (rigid)
Suspension Suspension-corrected; 30–40mm forks (Cane Creek, DT Swiss, Fox, RockShox)
Tubeless Shipped tubeless-ready from factory
Tire clearance
Position Clearance
Front 61mm / 2.4″ MTB
Rear (1x) 56mm / 2.2″ MTB
Rear (2x) 49mm
Mounts
  • Three bottle positions inside the main triangle
  • Downtube: 6 bottle bolts
  • Top tube: bag mount + accessory mount
  • Underside of downtube: accessory mount
  • No rack or fender mounts
Geometry
Frame Size XS S M L XL
Stack (cm) 53 55 57 59 61
Reach (cm) 37 38.5 40 41 42.5
Virtual TT (cm) 51.2 53.8 56.3 58.5 61
Head tube length (cm) 8.7 10.5 12.5 14.4 16.6
Seat tube length (cm) 44 47 49 52.5 56
Head tube angle 69° 70° 70.5° 71° 71°
Seat tube angle 75° 74.5° 74° 73.5° 73.5°
Chainstay (cm) 43 43 43 43 43
BB drop (cm) 7.5 7.4 7.3 7.2 7.2
Wheelbase (cm) 102.5 103.9 105.6 106.8 109
Front center (cm) 60.9 61.9 63.6 64.8 67
Standover (cm) 72.7 76 80.1 83.1 85.9
Rider fit & stock cockpit
Size Rider height Crank Stem Bar
XS 155–168 cm 165mm 70mm 42cm
S 163–175 cm 165mm 80mm 42cm
M 170–180 cm 170mm 90mm 44cm
L 178–188 cm 172.5mm 100mm 46cm
XL 185–196 cm TBD TBD TBD
Build Options
Base build Shimano GRX 820 1x 12-speed + DT Swiss G1800 Spline 25 DB — $4,549
Drivetrains Shimano + SRAM; power meter options
Wheels DT Swiss + Industry Nine
Full builder menu
Groupsets Shimano GRX 820 1x · GRX 820 2x · GRX 825 Di2 · SRAM Apex XPLR · Rival XPLR E1 · Force XPLR E1 · Red XPLR E1
Wheelsets DT Swiss G1800 Spline 25 DB · DT Swiss GRC 1100 · Industry Nine 1/1 GRCX · Industry Nine 1/1 Carbon Revive 2.0
Fork Rigid carbon race fork · DT Swiss F 132 ONE suspension (40mm)
Cockpit FSA bars (alloy / carbon) · FSA stem · FSA No.55R headset
Seatpost FSA SL-K carbon · Cane Creek eeSILK+ · FSA K-Force Light
Saddle Fizik Vento Argo R5 · WTB Volt · Selle Italia Novus Boost
Tires Panaracer X1 50mm · Vittoria Terreno T30 / T80 50mm · Continental 29×2.2″ · Maxxis Rambler 45mm
General Pricing
Build Price
Service Grava entry $4,549 to $8,349
Higher tiers Scale with groupset (Di2, SRAM AXS, Force/Red w/ power meter)
Customization
23 frame colors — Flat Finish (1) · Premium Gloss (8) · Premium Metallic (13) · Studio (1)
Lava Orange · Podium Gold · Argent · Blue Aegir · Velocity Blue · Wind Chill Pearl · Caribbean Blue · Chili Pepper · Cool Mint · Dynamo · Imola Red · Meteoric Dust · Mica Diamond · Monaco Yellow · Moon Gem · Pink Diamond · Podium Green · Prism · Pro White · Ruby Star · Speed Yellow · Stealth · Venom Green
Customization axes
  • Paint: frame, fork and logo/decal color each selectable separately
  • Drivetrain: 7 groupset tiers across Shimano + SRAM
  • Wheels: DT Swiss + Industry Nine options
  • Fork: rigid or suspension
  • Finishing kit: handlebar, seatpost, saddle, bar tape, tires
  • Power meter: optional
Total combinations: paint alone – frame, fork and logo each chosen independently from 23 colors – yields 12,000+ color permutations. Layered with the drivetrain, wheel, fork and finishing-kit choices, every Service Grava is effectively a built-to-order one-off. Regardless both can be ordered direct, the Service Grava at quintanarootri.com, the GVR at obedbikes.com, and in sizes XS through XL, painted, built, and shipped ready to ride from Chattanooga. And I would say they are in fact the very last bigger DTC brand that offers like over 100,000 specs options during the ordering process. If you cant find 100% what you are looking for when it comes to build specs. You should try golf. Or just ask the actual live chat person to talk to Chris Brown the VP of sales because knowing Chris personally he will probably make it happen for you.
Eric Wynn
Eric Wynn
Eric Wynn has been a seasoned industry insider for almost a quarter of a century. He sees the day-to-day operations around here while trying to learn how to write.
More articles by Eric Wynn →
Anyone else think Obed needs a better brand name or should just fold into Quintana Roo?
Does sound like it. but I guess mountain bikers have never heard of Quintana Roo and that remains the customer base for OBED.
Wondered where ‘OBED’ had come from and in the spirit of “Most slowtwitchers . . . know that both brands live under American Bicycle Group in Chattanooga. And if you didn’t.. Well now you know” I discover the Obed is a stream near the ABG HQ and six years ago they changed the name from Ocoee (was "a nod to the Ocoee River which flows just east of our Chattanooga headquarters. An old Cherokee Indian name, it is always with reverence and honor to those who came before us").
“With this history in mind, we decided proactively to change the name of the company in 2020. As with all naming decisions it wasn’t taken lightly, and was done to best honor those lost in the Ocoee Massacre. As Obed Bikes, a name taken from a stream that drains part of the Cumberland Plateau due north of our Chattanooga headquarters, we continue as a brand that steeps in the history of our region—but will always pause with reverence and honor those lost in those regrettable parts of our American history.”
