Can any one on the forum recall the sizing for the original 650c wheeled QRoo Kilo/Tequilo.
If memory serves me well a 55cm was the following
55cm from center of chainset to top of seat post
53cm from center of seatpost to centre of steerer tube
15cm steerer tube ???
I am looking to buy one from ebay in UK but seller is not to au fait with measuring ;-(
Is the frame size stamped anywhere
Its been about 12 years since I owned one so details are a bit hazy
Cheers from Alan in Scotland
Don’t know if this listing is of any help: (the listed weight of 3.4 lbs. was for the steel road frame -not the aluminum Kilo - so that is in error)
PS: John Major was Prime Minister when that bike was made but mine is still spinning away on the wind trainer
Quintana Roo has specialized in triathlon-specific bike frames for yearsAluminum aero tubing is lighter so you can save time on your next biking or triathlon event55 cm bicycle frame size47 cm C2C seat tube size53.5 cm C2T seat tube size53 cm C2C top tube size68 mm bottom bracket shellEnglish threads1-1/8-inch head tube diameter145 mm head tube length27.2 mm seat post diameter3.4 lbs.130 mm rear wheel spacingAccepts 650c size wheels
