Question about polar 625/training peaks
I recently added the altitude option (which I didn’t set) and now it’s graphing that. It’s cool because it gives me an idea of the terrain. however, when I upload it to training peaks, it doesn’t show the elevation part. Why won’t it upload that as well?
I use Training Peaks with a Garmin 301 so I’m not really sure – but have you tried both the “map” view and the “graph” view? The elevation profile shows up on my “graph” view.
Hey :slight_smile:
Check to see if there is an option in Trainingpeaks that allows you to select different types of views for the 625. I used it with the 725 and since the 725 has power and cadence options which can be turned on or off, Trainingpeaks may have the same options.
I used trainingpeaks for about a month, but I got tired of all toggling the extra features, found Cyclingpeaks and a good 'ol Excel spreadsheet were less complicated and I could write my own formulas for tracking hours trained.
:slight_smile:
  • Gary
on the graph on training peaks, the elevation is actually checked… but nothing is showing. now on my polar software, if i look just at the data, the mini graph doesn’t show elevation but the big one does… I am confused. wonder if it’s from the polar software that my problem stems…
Depending on the base elevation, the elevation line might be off the scale on the ‘mini’ graph, but the big graph will re-scale the elevation to get it to fit.
but it won’t show up on the training peaks website:-(
Try e-mailing trainingpeaks, or post a message to their forum.
