I have SRAM Red Quarq power meter and swopped the 53t outer ring with a 55t.
I knew I had to re-calibrate so I bought the Qalvin app for my iPhone and the Wahoo dongle. I watched the YouTube clip and zero’d the calibration and then went into ‘Calibrate Slope’, I used my certificated calibrated weight and went through the app process to change the slope.
I now seem to be 30w less power output on both average and normalised but I’m going faster? Have I done something wrong, anyone else come across this?
Funny I just posted a similar issue except I don’t have the weight. Did you buy one? Where’d you get one and was it like $200?
I’m pretty sure recalibration is required as I swapped my 53 for a 54 and power readings are off.
Yes that’s what I thought, you can do a manual or auto calibration but I thought that was minor check against atmospheric pressure or whatever, but the slope has to be recalibrated if you change the ring size, or so I thought, the Qalvin youtube clip seems to suggest that to.
I didn’t but the weight, I had a weight calibrated by a calibration company weighing in at 25.33kg, only cost £25.00
Do you have a Cinqo or a Red/Riken/Elsa? If its the former you absolutely have to change the slope with Qalvin. Iits a newer Quarq with omnical its not necessary.
Have you looked at Quarq ring calibration table? See if your rings are posted and check what Quarq recommends. http://www.quarq.com/ring-difference
Have you looked at Quarq ring calibration table? See if your rings are posted and check what Quarq recommends. http://www.quarq.com/ring-difference]
I have SRAM Red Quarq, I can’t find the rings in the table which is why I went ahead and calibrated them.
I’m still surprised you “re-calibrated” it in the first place. You didn’t have to. As mentioned, “omnical” is a feature that means you can swap chainrings and not worry about it. (assuming they’re installed correctly, obviously)
