Pumping a disc wheel - best tips & adaptors
My faithful crack pipe adaptor has finally given up on me. It was actually always quite a pain to use and difficult to pump the disc up on my own.
What do you use as a pump adaptor for your disc wheel? Are there any better ones out there than the standard brass crack pipe?
Anyone got any tips on how to pump a disc on your own?
Thanks
I have a Lezyne Travel floor pump that has a screw-on type pump head. For my disc I just pop on the mini-adapter shown here:
https://static.bike-components.de/cache/p/z1/3/2/Lezyne-Ventilaufsatz-Speed-Chuck-32908-0-1481258033.jpeg
In my experience, the functionality of any crack-pipe depends on the correct tightness of the o-ring that wraps around the valve when you press down on it. With this adapter you can adjust that by tightening or loosing the screw-in part that affixes it. My one complaint: The pump doesn’t have any way to attach it somewhere to it when it is not in use, so I’m dreading the day I will lose it…
Thanks
Yes buy one of these and be done with it.
https://www.sigmasports.com/item/Silca/Hiro-Side-Lever-Locking-Disc-Presta-Chuck-V2/BSVY
https://www.tririg.com/articles.php?id=2015_12_Silca_Hiro_v2_Review
Years ago I had my pump with me in a shop in Germany and the Owner saw the chuck on it, snipped it off and said this would be way better. I’ve been grateful ever since! Works a treat with my disc.
£105 for a pump head WTF! I think that one above couldn’t have been much more than €5.
Yes but it actually solves a problem and pretty much lasts forever. I no longer have to use one hand to hold the crack pipe on the valve and one hand to pump. It locks on like any pump head, and will work with any existing pump.
I have both the Silca HIRO V2 and the Silca mini chuck (crack pipe). I love them both and highly recommend them. I got the HIRO first, and it is the best for everyday life. I got the mini chuck because the cutout for my HED disc wheel was a bit tight, and I wanted to try the smaller chuck. It works well, but it is not as secure as the HIRO. (For example, when pumping my wheels before a race, when the bike had dew on it, the mini chuck would slip off.)
https://silca.cc/collections/floor-pumps/products/hiro-locking-presta-chuck
https://silca.cc/collections/floor-pumps/products/disc-wheel-mini-chuck
I found and bought a KCNC fitting on e-bay for around $40 that locks onto the presta valve and fits into a disc hole. It’s similar to the Silca but a lot less $$.
I put it on my Lezyne travel pump and combined the two make for a great pump that fits in my transition bag… and I can pump up my disc by myself with zero issues.
"]https://forum.slowtwitch.com/...isc_P6514591/
Thanks all for the input…I will try to find a cheaper option that $105 if I can though
I bought a fumpa pump for my disk.
Its usb charged and can fill 6 tires per charge.
It has a digital Guage and the attachment fits on my premier tactical with no extra piece.
I get to transition, and can pump it with one finger. At this point it basically lives in my transition bag.
The Silca HIRO is $65 USD.
I bought a Hirame adaptor years ago. It’s been pretty flawless for me. I have a Zipp Sub-9 tubular disc and it works/ fits in there perfectly. The best part about it is that once you lock it down, you don’t have to hold it while you pump it up.
https://www.tracksupermarket.com/media/catalog/product/cache/1/image/616x411/9df78eab33525d08d6e5fb8d27136e95/s/p/sp_kuwahara_pump_l.jpg
https://www.tracksupermarket.com/staff-picks/hirame-kuwahara-pump-head-presta-adapter-replacement-seal-3-pack.html
What disc do you have? Is the valve accessible from either side of the disc (i.e. Flo disc, zipp super 9, etc), or is the valve only accessible from one side (e.g. Renn).
If the valve is accessible from either side, I have to recommend the Lezyne ABS2 chuck head. It took some time for me to get fully used to the method of engagement (I can comment more on that if wanted), but it is an excellent disc head without the silly Silica price tag.
The ABS 2 works best when you can access the valve from both sides (you have to thread it on a little)
https://www.tracksupermarket.com/...ent-seal-3-pack.html
Is that the kind of thing you can swap from pump to pump easily or is it pretty permanent once installed on a pump?
Could you take it to transition & attach to a pump ?
I took an older pump (Lezyne Floor Pump) and permanently attached it to the hose. It’s definitely not as plug and play as your typical crack pipe. Which is part of the reason it works so well.
You can make an adapter from your pump to the Hirame adapter head, that’s what I did. I couldn’t get a consistent seal just using my normal pump head to the Hirame adapter.
If you have an old busted pump and a tube with a flat and a couple of appropriately sized hose clamps.
Cut the hose from the old pump to about 4-5 inches.
Strip a presta valve stem from the old tube.
Insert the valve stem and Hirame adapter into the opposite ends of the shorted pump hose.
Secure each side with hose clamps.
Use normal pump head to connect to presta valve on the fabricated adapter and the Hirame end to the disc wheel.
I use this only with the disc wheel so it preserves the expensive Hirame adapter. I kept it in my transition bag. The other benefit is that any pump could be used in the transition area if my pump was left in the car or at home or busted.
Thanks
https://www.sigmasports.com/...Presta-Chuck-V2/BSVY
https://www.tririg.com/...Silca_Hiro_v2_Review
I tried one and found it large, overly complicated, and cumbersome. I do like the regular Silca “crack pipe.”
Overly complicated?
Shove it on and close the lever. :slight_smile:
Thanks for this thread as I was about to start one of these…for my last disc, I gave up on the Silca disc adapter and just used a regular pump which slighlky bent my disc, but it was a plastic disc cover so I didn’t care all that much. It very well may be user error, but I have found the disc adapters virtualy worthless.
Here are my requirements
(1) must work without multiple hands
(2) must fit disc with hole on only one side (like my HED) with zero risk of scraping or bending disc
(3) must be a plug and go solution, be secure and work-sounds silly but I have tried several adapters that I could never get to work–that very well may be user error but if I can’t stick it on, pump and fill my tire without holding the adapter onto the valve, then I’m calling that a manufacturing design flaw ratehr than user error.
Fumpa seems to be a solid option. It is small so great for transition, looks like its plug and pump, and electronic gauge is a bonus. For a one and done solution for this, I would probably be willing to pay $100, albeit begrudingly.
I simply take a valve extender and thread it onto the valve leaving the extender sticking up at the side of the disc. Then pretty much any pump head can be attached to the extender - pump, unthread and you’re done.
A long extender helps.
I have a crack pipe but have found using the extender method is easier by myself
