PT hub won't trasmit
I have a wired PT setup and just switched to a diffrent rear wheel. I can’t get the CPU to recognize the different hub. The batteries in both the CPU and hub are fresh. I’ve tried the find function repeatedly but still not getting them to sync up. Any input is appreciated.
bro,
you need to go to the learn function not the find function:
  1. Spin the rear wheel to wake the hub out of sleep mode.
  2. Hold down MODE + SELECT till you see a screen that says “SEE EDt” with numbers 1-5 at the bottom. These are menus.
  3. Press SELECT till the number 5 is flashing
  4. Press MODE
  5. You are now on a screen that shows the HUB ID, which is a 5 digit code. It is set to the last hub your PowerTap computer was talking too.
  6. Press MODE, which scrolls through the numbers (you can manually set the numbers by pushing SELECT), till you see the word LEARN
  7. Hold down SELECT till LEARN starts flashing. Let go of SELECT. Your computer will now find the hub and store the 5-digit code!
  8. Continue to press MODE till you exit the Menu
  9. Go out and put the power down!!!
Thanks to trisports.com for this
Therein lies my problem…I get the option to learn spd, cd or hr. But, I never get an option to learn the hub. It is really starting to drive me crazy. Thanks for the help though.
