Just want to make sure that all Powertap G3 hubs are 11 speed compatible.
I had another wheel that already had an 11 speed freehub but I think it had orange letters. This one is yellow.
Easy peasy. Will check tomorrow morningIt should be compatible - worst case scenario with a different freehub. i recently looked to upgrade my old Powertap Pro+ but it has a 12mm axle and therefore did not work.
Yes it will be compatible. All the G3s are based on the 15 mm axle. The Shimano freehub has a spacer to convert between 10 and 11 speed. There is maybe a chance that it would have an older freehub body if someone swapped it out, but I am almost completely sure that these are Novatec freehubs. Much cheaper to pick those up off of Ebay.
