Do the G3 and GS hubs come with the auto zero function set as a deflault to be on ?
Reason I ask is that I have bought a GS hub and although it’s not built into a wheel yet, it wakes up when I spin it and talks to both my polar v650 and the Powertap iPhone app no problem.
I can’t see an auto zero option on the v650.
I can see the ‘auto zero offset’ switch in the app but it is defaulted to the off position and can’t be altered to the on position manually.
The Powertaps Auto Reset when you coast.
You should do a manual when switch the head unit between wheelsets.
If you do not change wheelsets or bikes with head unit, you should be good.
Note: I use PT Joule and do not link my PTs to any Garmin or Polar products.
I would say you have proper function if you spin the hub and it reaches out and speaks to your Polar.
I have the P1’s and v650. If you are paired, when you start the exercise event and hit the left side button you will see an option to calibrate power. This should zero offset them for you.
