So I live in a country that apparently doesn’t deserve replacement cleats for my P1s.
Can I use Look KEO without problems?
“Look Keo compatible” is a total shitshow of a standard that I can’t get any straight answer on. What I know is that they’re not all the same. I can’t clip into the new IQSquare pedals with Favero cleats (which also work on P1/P2). I had to switch over to the “Look compatible” cleats the Vectors use.
In short, what will work is the same cleats as the Assioma. If you can’t find PowerTap P1/P2 cleats, get yourself some ‘Favero Assioma’ cleats and you’ll be good.
You want Wellgo RC7b (6 degree float) or RC7 (no float).
You can get them for <$20.
P1’s (and Assioma’s) cleats are, in fact, Xpedo’s “Keo compatible”. Those shouldn’t be hard to find
Do you have a trusted relative or a friend that lives in a country that does?
Yep correct. Wellgo apparently make the cleats for PowerTap. The Wellgo branded version is identical to the PT version but significantly cheaper.
Look cleats will work in an emergency if you have no other option, but they are not ideal as a long term cleat.
I found some original PowerTap pedals, thanks all.
