I’m sure that this topic has been addressed in the past, but here it is anyway:
When training with a powermeter indoors, what is the relationship of power to size? I know that if I weigh 175 pounds, I’d have to crank out more watts to go the same speed as someone who weighs 125 pounds. But that’s considering gravity, wind resistance, and (most importantly!) inertia. If we’re both stationary, none of those things matter, right?
I am curious, because I seem to put out far less power on the trainer. On the road, a very comfortable conversational pace might be 180-200 watts. On the trainer, that same comfortable range (with a comparable heartrate) is more like 110-120. Super low!
So…what’s the skinny? I have no doubt that people have geeked out over this topic before.
That link was very interesting, but it still doesn’t explain output on a trainer vs outside. Does my question make any sense? Again, I understand that the power necessary to push me down the road at 20 miles per house is greater than the requirement for someone smaller/lighter under the same conditions.
But if I’m sitting on my trainer in my basement, and you’re right next to me, am I correct that our individual sizes no longer matter?
Assume we’re on the same bikes, in the same gear, with the resistance settings on our trainers identical. Rear wheel mounted sensor. I weigh 170 pounds; you weigh 220. Your girlfriend joins the fun (her fantasy, I’m sure), and she weighs 120. If we all pedal our identical bikes on identical trainers the same speed as measured by the speed of the rear wheel…then are we not all putting out the same power??? It no longer matters that you’re a fat slob and your girlfriend is as thin as a rail. Gravity, wind, intertia, etc. are all moot.
no we’d not all be putting in the same power. The heavier person requires more wattage due to additional friction.
Now that assumes a computrainer which takes weight into consideration.
If you are riding with a pwm like a quarq or srm…then if you are all riding the same speed I would think the wattage would be pretty similar since you are removing most external factors.
are you asking why 20mph on the trainer takes a different amount of power than 20mph outside?
that’s because the trainer isn’t custom made to simulate the same power curve as you outside exactly.
are you asking why you can’t make as many watts on the trainer as outside? that is usually due to cooling (you need a bigger fan) and inertial differences (you need a bigger flywheel)
Am I off-base?
Seems simple to me. The 120 pound and 220 pound person need to pedal exactly the same watts to go 20MPH on the trainer. Outside, the big guy has to pedal harder.
Maybe I’m missing part of the question. Maybe you are over thinking it. Not sure.
your power relative to your FTP is whats important for training on an indoor trainer.
watts/kg might be used to compare people for climbing and may indicate how powerfull someone may be for their size. that would most likely translate to faster speeds per watt outside too.
most trainers lock the rear wheel in place, so weight would not be a factor, other than a heavier person produces more heat, so will be more negatively effected by not having a big ass fan.
but, regarding question #1: believe what you want but its true anyway. heat and flywheel are why its harder to produce the same wattage on a trainer as outdoors.
simple test: do a 20 minute test with and without a bigass fan =)
I guess it’s a two-pronged issue:
the whole indoor vs. outdoor speed and power is one thing (and I have a hard time believing that heat is the ONLY explanation) and
whether watts/kilogram means anything when one is stationary. I say it doesn’t, but I’m an idiot.
That other thread linked above is helpful for the issue #1.
Am I off-base?
I totally agree. That’s my thesis exactly.
I guess where all the confusion comes in is how the two issues interact.
Outside: I weigh 77 kg, and my friend Sean weighs 63 kg. If we both are capable of riding at 3.5 watts/kg comfortably for an hour, then that means that he normally does 220 watts for an hour. I, on the other hand, would be accustomed to doing 269.5 watts for that same hour. We’re out on the road. I weigh more, etc. I get it.
But now we go inside: What the hell happens now??? Do we both have the same output???
It’s normal to struggle a bit more to put out the same power indoors. You have to use a good fan to keep from dehydrating and driving your HR up after 30 mins also. I’d just measure how much power you average for 20 mins indoors and base your workouts around that number and don’t worry about outside numbers.
you would both do a little less than your outdoor wattage, depending on the trainers flywheel and cooling.
this is simple stuff, relax, think =)
How would you get more weight on the flywheel if the tension between the trainer and tire is done with a screw?
jaretj
It seems like one of the features of the more expensive trainers is a heavier flywheel. I guess you could build a heavier one or attach weights to the bike wheel if you were handy. My e-motion rollers use a belt driven flywheel that seems to help a lot
there is still contact.
On the road there are going to be two contact points. Front and rear tire.
On a fluid trainer there will be four.
The front tire (inactive)
Both sides of the skewer (bolted in)
and the Rear tire
The rear tire still has pressure on it. Not the same amount, but if you were to pedal with nothing on the saddle and then with a 400lb man on the saddle, it would be different.
"The rear tire still has pressure on it. Not the same amount, but if you were to pedal with nothing on the saddle and then with a 400lb man on the saddle, it would be different. "
