I am looking to see if anyone has any feedback they can share on the above manufacture crank-based power meters? Only reason I am asking is because I am looking at going to a 150mm crank arms with a power meter on the new trek speed concept. I am being told Rotor crank based power meters will not work due to clearance issue.
Thanks Ike
Power2max are a great crank based power meters.
I have one myself and work with many amateurs and pros that have had great success with them
Agree with the above, ive had a couple they havent skipped a beat. Has the seal of approval from GPLama too. I wouldnt bother paying the extra for the expensive one, the NGEco is perfectly good enough.
I’ve got a P2M paired with Praxis cranks with no complaints. Only minor issue is that it reads 5-10w lower than the Quarq it replaced. My ego didn’t like that.
Thanks Ike
Who’s telling you they won’t work on a SpeedConcept, and why wouldn’t they work? The new version of the SC has a T47 BB, I would think clearance shouldn’t be an issue any more.
Being told the only issue is with the rotor crank and having a clearance issue with that BB. They gave me an option for the power2max crank to overcome the clearance issue. My bike fitter gave me this information. Tony West out of Indy. Awesome guy.
Just and FYI, P2M does not make any cranks. They make spiders and sell other peoples cranks (Rotor, Praxis, Campy, FSA and others). You’ll still need to do your research on what crank/spindle/bottom bracket you’ll need for your frame and or existing cranks (assuming they’re modular and not Shimano based).
Thanks Ike
We installed a P2M NG with Rotor ALDHU Carbon 30mm 155mm cranks on my wife’s 2023 Speed Concept. No clearance issues. I’m not sure what might be different with the aluminum ALDHU arms.
Make sure someone isn’t telling you about an issue with Rotor cranks using a Rotor power meter.
Also consider contacting P2M NA or Rotor directly about compatibility. Another solid resource is Power Meter City.
I have found their customer service to be excellent also. I bought one of their first generation meters back in 2010. For 10 years it served me well but in 2021 it finally died. I contacted them, we had an efficient email exchange and even though it was well out of warranty they offered me a crash replacement which was very good deal. Again, emails back and forth to make sure I got the right cranks etc and then more correspondence to help me fit it etc. No hesitation to buy from them again.
