I just purchased my first Quarq and have been testing accuracy vs. my Assiomas and Tacx Neo (OG).
I’ve done lots of testing …
Assioma’s pretty consistently show +5-15w vs. my Neo (~3%), and sometimes the variance is up to 0, sometimes 5%.
Quarq is showing +10-15w vs. my Assioma’s (another ~3%). I’ve only tested this 3 times now, but I’m always off…
I do most of my training indoors, so seeing a 30w bump outside is super impractical.
First point is Tacx accuracy is garbage if you are on the big chainring. So, did you do your tests below 15 MPH on the Tacx? Assioma is usually lock-on with a Tacx at slow speeds. Fast speeds and the Tacx loses it.
Those two are generally considered best of breed. They should be close. But based on your posts and data from your thread a year ago, I suspect that you have a bad set of Assioma pedals.
It doesn’t matter, does it? Set your preferred PM of Quarq or Assioma to control your Neo. Do an FTP test to set your baseline. Consistent power readings going forward.
I had emailed Assioma and they basically said F-Off. not very helpful at all.
Is there?
Originally, virtual elevation wasn’t developed as an indirect way to determine drag – it was developed as an indirect way to determine power meter accuracy.
I calibrate before every ride, and then usually once about 15 mins into the ride.
I may be mis-interpreting, but “calibrating” when accuracy issues are involved usually entails static calibration, not taring (aka performing zero-offset). What you are describing is a zero-offset, not a static calibration.
