working with a therapist for about a month now and he says i can start the slow return to running program.
I have a mild case, arches have not fallen, but after months of not running, i still have some discomfort. need to consider that something on the bike set up/shoes could be a problem.
i’m also gonna do a few other things based on doc/pt recs (like orthotics for everyday shoe use)
anyone have any experience/thoughts on the best type of shoe (or brand - considering brooks glycerin) for ptt?
Had this in 2014-15, 7 months of no running and funny enough, have started to feel it coming back in the past couple weeks. No outright pain but it is giving me warning signs. Or maybe a 0.5/10 on the pain scale.
I switched from whatever neutral shoe I was in to brooks adrenaline, asics gel kayano, and now nike zoom structure. So basically, “stability” shoes. The goal was to just have a shoe that limits the medial collapse and all those do the trick. I found zoom structures the fastest because they are lighter and use better materials than brooks & asics (maybe not anymore but back in 2017 when I switched it did).
The reason it is threatening to come back is that I have been testing a shoe prototype that is completely neutral for the past month. Also because I stopped doing those strengthening exercises like pulling my foot with bands and stuff… so be sure to do your exercises, be diligent about it and don’t ever stop them because 6 years later it may just come back because you decided to try a new shoe…
has nothing to do with your shoes. your hips lock and twist your knee ankle as you run, fix that. start with some up hill treadmill running will start building a better habit and stop the issue of pulling on your tendon.
good luck, everyone has different runners and the same injury, it isn’t your runners.
I wasn’t really blaming my shoes but looking for a pair that helps mitigate the discomfort when running.
in therapy now. pt has me doing all sorts of strength stuff and using graston technique. i have not started running again yet but will be soon and slowly entering that discipline. i’ll ask him about your suggestion for sure.
If your physio is using graston. They are very likely to not no what to do and would rather you keep paying them for x time rather then fix it with simple exercises and run abilities. Good luck. How does rubbing your muscle fix the lack of run skill and pelvic control and balance required to never have the injury in the first place.
likely multiple pathways to wind up with this injury and certainly also multiple pathways to heal it as well.
also likely that each injurious pathway has its own ideal healing pathway.
i’d love to read any research/literature that you have on your suggestions.
serious, not snarky. i’m open to all background, information, suggestions, alternatives to traditional treatments, etc. that expands my knowledge and hopefully helps me improve and/or heal.
Have you tried just very good insoles? A good base for the foot is everything.
For years I use Bauerfeind Weightflex 2. I’m very bad overpronator, with very high arch, I couldn’t manage the pain on the inside part of the ankles, then I found Weightflex, mk 1 then (stil use them in my garage shoes). I can put them in every shoe (usually I have to buy one size bigger one). Very good support. The best that I had encountered ever.
My advice: As I was explained by a physiotherapist good insoles “hurts” at the beginning, because they are molding the foot to correct position. For first weeks it could be difficult to wear them all day, but no problem - wear them few hours at the morning, few at the evening etc. The change will come.
Edit: Weightflex has 3 levels of support (which translates to big plastic, elastic blue X X X on the on the back side of insole) and two widths: normal and wide, so you can pick what level of support below arch you need. Because they “X” are really blended into insole the feeling of a big bulge below the arch is limited.
Edit: Thanks that Weightflex are really thin I manage put them below stock insole of the shoe (that’s why one size bigger shoe for my high arch is needed) and so do not loose the amortization from the stock insole.
I was using 10 years ago also first edition of the sport orthoses of Bauerfeind but I found them sturdy and because they were thick I had to were them instead of the stock insole. So when shortly after Weightflex came, that was like revelation for me. But now I see that Bauerfeind produces tailor-made orthoses for every sport, so the new generation came, but I didn´t try them. I´m sticking with Weightflex.
actually there is only one pathway to a tendon issue , the locked muscle under load that is preventing the muscle from proper use that leads to the tendon taking on the lengthen responsible which it is not designed for.
I muscle has lengthening abilities a tendon is like a tight spring, and you are trying to length the spring that is not how springs work. SO it yells at you to stop, once you change the one pathway it will stop. THAT is the only pathway, treatments with not fix that just better form and skill. That is a learned behaviour like swimming.
Just in swimming you go slower in running you get hurt, much higher force load.
You will have to go find what studies you want. the problem with studies is you can make anything prove something if you add an exercise component in it ( grastons, wave, massage, acupuncture ) or make it seem competitive with a retest as humans like to improve even through more discomfort.
There are not enough trainers that know or take the TIME to teach and fix. ( treating quick and so you come back is so much more profitably) You will need to find one in your area.
I got PTT from ramping up mileage too quickly and probably years of overuse as an overpronator. Switched from a plethora of shoes to just using my Brooks Adrenalines. Also bought some custom orthotics from upstep to put in my everyday shoes. The problem was fixed in a few months and I decreased mileage from 40-50 mpw to about 25-30 mpw.
I highly recommend the upstep insoles. They were cheap (for custom) and every step you take makes the PTT worse. I’ll take 5-10k steps a day on a non running day, and that’s all doing damage with bad shoes.
I’m not really clear on your background or knowledge base, but you are misrepresenting anatomy and physiology. Tendons are not springs, they are part of the contractile unit. Tendons under load respond to this load and increase size based upon the stress it incurs. The OP injury can be based on many things, local dysfunction is the first place to look. Your implication of pelvic instability may be a component, but truly ignores the capability of all the structures from the ankle to the hip to absorb and ameliorate stress. You’ll have a tough time proving hip dysfunction causing ankle problems in the absence of other ankle-foot dysfunction and knee dysfunction.
A tendon is a reflex just like a spring. IT loads and releases, it has no other force function.
Sure it holds the muscle to the bone. But why do we look at the reflex tissue and not he controllable tissue. As the cause of the injury
Second your hips hold wt position over your foot move you hips around see how your feet and pressure response. The top controls the bottom. Not the other way around. These are reflexes not ideas and thinking. The body reacts in under .1 sec to a movement you cant think, you teach movement rythm and reaction.
Once again, your belief is wrong. A tendon is not a spring. The reasons tendons are injured more often than muscles is due to its limited blood supply and therefore healing ability.
Secondly, I don’t understand your example of why the hips cause ankle pain. However, you once again make incorrect assertions. Motor control and neuromuscular adaptations are absolutely trainable. It is wrong to believe that only the hips cause ankle pain. You’ve dismissed every single lower extremity structure over a 3 foot span as an ability to absorb stress. Do you have stilts for legs?
This is not an absolute, as you make it sound. My issue was caused by shoes, as my ankle collapses inwards, the PTT rubbed against the protruding bone and became inflamed. That is what I was told and shown by a very good podiatrist in NYC. Before that injury and multiple times since, I have had run form analysis which showed no issues with my hips or knees. Since that injury, wearing the right shoes, I have ramped up mileage to 50 miles/week over the last 3 seasons. In all that time, I used 3 different brands but all with good medial support. 4 runs wearing neutral shoes in two weeks and I am getting issues. Perhaps what you are saying is the more likely case rather than it being shoes, I can accept that, but it not an absolute.
Like you, I had a mild case, e.g. pain, but no fallen arch. I didn’t change shoes, but started using Superfeet green insoles in my running shoes and biking shoes. That was about 15 years ago, and I never had PTT issues again.
Weird, but I wear Powersteps in Ecco dress shoes daily
Not weird. The foot need a proper support and correction fo all day long to function properly.
Aetrex are too soft, gives to little support, in my opinion, just foam, no structure. I tried one for 5 minutes and felt that my ankles are prone to twist inside once again. So I stayed with Weightflex.
