I’ve been riding q-rings for the last five years. During that time I have done several tests on different settings and always come back to #4. This winter I switched to compact, 155mm cranks (from 172.5mm) and thus raised my saddle 17.5 mm (that’s the only position change I made). This change has, of course, opened my hip and knee angles. I’m on a P3, and I don’t know how the seat tube angle has been affected by this change.
If the knee/hip angle at the start of the ‘power stroke’ is constant with regard to position, then I would think that I need to move the q-rings back, perhaps to position #2, because I am now reaching that knee/hip angle earlier in the pedal stroke. This makes sense to me, but it kind of flies in the face of the conventional Q-ring wisdom of “#4#4#4!!!”. I don’t know what other factors may influence the ‘power stroke’.
Has anyone else thought about this? Any ideas before I just start moving rings around willy-nilly?
what’s your effective STA and what was it that lead you to 4 and not 5 when tinkering
Not sure about my STA. I thought the P3 was a bike with constant STA regardless of saddle height?
There was no single thing that landed me on the #4 setting. Several times I got the itch to tinker, so I would do several rides (on familiar courses) on different settings, and also on round rings. I always made my way back to #4.
I’ve run into something similar on my bike, also with a vertical seat post.
Although a time trial bike, and Rotor recommending that the ring be run in position 4, I’m both faster and more comfortable in position three.
A saddle change and some completely new fit settings to try, moved me around quite a bit on the bike. I too was expecting to re-index the rings, but adjusting in the direction which I thought was logical turned out to be a step backwards.
I’m still faster over 10 and 25 miles, as well as more comfortable in position 3. I wonder to a degree if much of it is acclimation to the index position.
Whatever it is… I too find that the index position doesn’t seem to move, even when I reset my position on the bike…
BB to the point where you effectively sit. If it’s 80+ I’d stick it in 5 and get used to it there. The steeper you ride the higher the number on the q-ring for you to be in the FAT spot of the pedal stroke in the right spot on the rings.
