The title of my post basically says it all, but it doesn’t really portray how bad this problem really is for me. When I ride for extended periods of time, even for the 56 miles of an half IM, the soles of my feet (just under my toes) and the outer side of my 5th toe go numb…so numb that it actually becomes excruciating to the point that when I get off the bike to run, it’s useless as even walking would be a problem. It’s worse on my right foot, but it does happen to both feet. Aside from the numbness/pain, I can’t run off the bike like this!
For reference, I wear SIDI T2 tri shoes (2 years old) with orthotics that were molded for my feet around the same time, and I use Shimano cleats (yellow)/pedals. My left leg is longer than my right leg, and during a recent bike fit, my fitter put three shims on my right cleat. My SIDIs are size 40, and while they are just the tiniest big on my right foot, my left foot is longer and couldn’t wear smaller than a 40. Also, I have very high arches, narrow feet (very narrow heel, but toe area not narrow), and I do have a tendency to supinate/underpronate a bit.
I have tried many things. I have moved my cleat back (further back on my right foot than on my left); I have shims on my right cleat for the leg length discrepancy; I tried putting a varus wedge under the insole of my right foot inside the shoe (under the ball of my foot/toe box); and I have loosened the velcro straps on my shoes mid-ride. The problem occurs both when I’m sock-less and when I wear socks. I do have Reynaud’s Syndrome, but this occurs in all temps. I also have the Specialized S-works road shoe, and tried it for 2 races last season since I had been training with them, and I still had the problem (although admittedly maybe to a lesser extent).
I have done some searching on the forum, but I still can’t come to a good summary of what my exact problem is/how to fix it. So, if anyone has any ideas, suggestions, and/or recommendations on what I can possibly do to get relief from this issue, I would be forever grateful! THANK YOU!
eta: I don’t have this problem when running. It is only caused by cycling and persists into my run when I go to “run” off the bike.
