I have just recieved a nice new R3 frame as a replacement for my R2.5. I am mainly going rebuild using the parts from the R2.5 - but having such an Uber light frame it doesn’t seem right not to pimp it up a bit (over time as finances allow). I have a full DA group set to fit on it + Syntace F99 stem and some Less 199 bars, Zipp 404 (for special occasions) and some Mavics for general riding around.
What should I look to replace?
The seatclamp looks pretty industrial (anyone know how much it wieghs?). Any recommendations of a lightwieght alternative, if so what size would I need? I understand M2 racer made a nice clamp but they seem hard to get hold of in the UK.
I presume there is an engineering reason behind Cervelo decision to use an oversized seatpost? Taking this into account is there a reason not to go for a standard sized post with a shim? USE’s Alien and Easton EC90 are the posts I am looking at - I think the USE is a bit lighter and is cheaper here in the UK than the Easton, but I got to keep my Easton Forks from the R2.5 so I guess the Easton post would match in nicely.
I have also thought of changing my Fizik Arione saddle for either a white SLR or Specialized saddle.
Is there much weight savings to be had from replacing the DA cranks with the new FSA cranks - considering the DA cranks function very well. I have thought about Zero gravity brakes are there any similar brakes I could also consider?
