Power Cranks plus Computrainer makes it possible to understand (your) pedal stroke.
Most of the posts I have seen re PCs report improved performance (and a fair amount of replies from skeptics). I just bought a second pair for my other bike because, since I put PCs on my number one bike on December 29th my other bike doesn’t get used. I did this because I have experienced a quantum leap in performance over the past 3 months AND because, for the first time, I believe I am beginning to understand the elements of an efficient pedal stroke. This understanding came about by watching my CT spin scan before and after PCs.
I am a relative neophyte to biking. I have been doing tris for 2.5 years and biking is completely new to me. Since I knew my pedal stroke was extremely weak, I read a whole lot about pedal stroke. I got lots of conflicting information and really didn’t sort it out until I found the formula, UPS=PC+CT
Which is my dominant leg?
bPC: My right leg persistently dominated my left, l:r = 52:48. I could make this go away if I really concentrated on it; otherwise, it was there. I assumed this was because I am naturally right legged, based on the old days of playing soccer.
aPC: My left leg persistently dominated my right leg, l:r = 48:52 (when I began). I learned that my right leg is weak (slow) at lifting up and over. Also, I found adjusting my right cleat forward helped. With fixed cranks, my presumed weak leg was actually helping lift my presumed strong leg. I would not have figured this out without disconnecting my left from my right.
The mystery of spin scan numbers?
bPC: Ever since I got the CT 7 months ago, I have been trying to figure out what an optimal range of spin scan numbers is. The CT book says the pros pedal in the 70s. Well, I started in the low 50s and learned how to pedal in the 80s, occasionally touching the 90s, at a cadence normally around 95-105. This requires a downward pointed toe at the top and very little ankling. I was very close to pedaling circles.
aPC (and advice from John Cobb): I ankle. Since I have swimmers flexibility, I ankle big time. My cadence is usually between 60-70 but I can bring this up to 80 if I want, but higher cadence for me is slower. My spin scan numbers are typically high 50s to 70. These numbers are a function of cadence and resistance. At low resistance, it is difficult to maintain a good looking peanut shape on the polar plot. At high resistance and lower cadence the polar plot looks really good, spin scan ~65. My sweet spot, currently, seems to ~65. I no longer care what the pro’s numbers are.
Attack angle?
bPC: Using the polar plot, my attack angle was typically around 105 deg. And the phase difference was such that both legs had very close to the same attack angle.
aPC: Initially my attack angle was all over the place and, of course, one leg good easy be 10-30 degrees out of phase with the other leg. Without a CT you can feel this pretty easily. But when the legs are only a few degrees out of phase, it is not so easy, at least not for me. Learning to ankle, learning to smoothly lift each leg, adjusting my cleats a bit - what a difference. Now I don’t fixate on the polar plot and when I look at it there are my legs humming along as though they are connected by fixed cranks. What a nice feeling.
Conservation of angular momentum?
bPC: With respect to pedalling, I never thought about it and never read about it.
aPC: Now I feel it. What the books describe as scrapping mud off your shoes is a crude way of describing what you need to do to help conserve angular momentum, developed primarily during the down stroke, as you come into the up stroke. This feeling can be obtained to some extent by single leg peddling on fixed cranks. But your non-peddling leg is never in the right position and your hips can’t possibly participate correctly. Now I feel my calfs, hip flexors and back muscles all working together to conserve angular momentum. This has got to be a good thing, I think.
Performance changes?
I have made numerous changes over the past 8 months and all of them have helped. But only one change correlates directly with my sudden improvement. Now, I know that correlation does NOT prove causation. But good science starts by paying attention to correlations.
bPC: Long rides (3 hour max) at ~14 mph. Short (1 hour or less) rides at 16-18 mph.
aPC: Long rides (4 hour max) at 17+ mph. Short (1.5 hours or less) rides at 17-22 mph.
Evaluation to date
I suspect that people new to biking will experience a more sudden impact from PC training than those who have biked a long time. BUT, I think almost everyone will understand there own pedal stroke better and improve upon it by training with PCs. How much they improve remains to be seen.
I follow the debates on Slowtwitch about the scientific basis as to why PCs will make you faster or not. These are interesting, amusing, and sometimes educational. I for one am fairly certain that our scientific knowledge regarding biomechanics, muscle and cardiovascular physiology, neurobiology, and biochemistry is insufficient to analyze this problem. That doesn’t mean we shouldn’t be trying but it does mean that in the mean time what you have to go one is anecdotal data. That’s what you got here.
Bill
