I have the PT 2.4 wireless (about 3 yrs old) and am trying to pair it with the new Garmin Edge 500. The manual isn’t too informative and there’s about a 40 min customer support wait on the Garmin website. Any suggestions/tips here? Thanks in advance.
From menu, select settings, select bike settings, bike 1, ANT+ power, scan. Make sure the hub is activated before starting.
Kevin
Maybe I don’t know what I am talking about but I thought only the ANT+ hubs are compatable with the Edge 500. Those hubs are model 2009 and later.
Yes, but they can be “updated” to Ant+ protocol.
Flying Wombat has it. I have an Edge 500 and 2 different powertaps (training and race wheels). You only have to “pair” it once (the rescan procedure), then it will pair and work immediately once you start pedaling.
But you make a good point, the OP has hopefully updated his older hub to ANT+ via the thingie you “rent” from Cycleops.
Kevin
I can’t seem to pair my PT SL+ hub. Menu>Settings>Bike Settings>Bike1(my only bike on the 500)>ANT+ Power> Then I hit Rescan optionand it just backs out to the previous menu. I pedal and pedal and nothing happens. I know my PT batteries are good.
Your PT SL hub probably isn’t ANT+. I had this problem with my 2008 2.4 wireless hub. I had to buy the ANT+ updater. I have an updater with presumed 1 update left if anyone wants to try it out. It has been used twice, but rumor is that it will work 3 times. Let me know. We can work out a deal of some sort.
Where do you get the ANT updater and what did it cost?..I need to obviously update a wireless PT that I’ve had for at least 5 years…would be interested in working something out with you…please let me know…Thanks
if you have an edge and the 910xt wrist garmin can both garmin’s pull the data from the powertap? i just use the edge to display the data but i load all my workouts using my 910xt
no problems, the hub simply broadcasts its data, it has little to no idea where the data goes.
the pairing process as I understand it simply informs the garmin unit which powertap ID to listen to.
I have a 910, an edge500 and an edge 705, all 3 will simultaneously display the PT data. ( no I don’t run all 3 together normally, :p)
Make sure your PT is in fact ANT+ and if you’re still having an issue, check the battery.
You order it from Saris, it’s $120 (roughly)to update to ANT+. When you’re done you send the module back and they send you a t-shirt.
Here’s what the ANT+ updater looks like. $99 at Saris and I’m sure Amazon has it too http://www.cycleops.com/products/accessories.html?page=shop.product_details&flypage=flypage_images_norating.tpl&product_id=179&category_id=8
