My understanding of the 3T Aduro is that once you select the macro height setting (Low, High-V) then
a) you adjust the height by cutting the steerer tube
b) you cannot have spacers above the stem to keep a little extra steerer tube around
Thus, once you go down, you never come back up.
As much as I am a sucker for new bike technology, I find the lack of ability to raise my bars quite troubling. I know you can use another bike to get your fit dialed in (and I have this), but that’s not the point. Isn’t fit always a slightly moving target? Trying out new positions and refining as you go?
I could see the argument that this bar is for pro’s and people who have their fit dialed in perfectly, but that doesn’t seem to be the design point for the rest of the bike. They’re focus is on the “simply” part, and the thing is adjustable upward to the point that it’s like a beach cruiser, so they’re clearly marketing to the amateur athlete. It seems like a strange combination of design points.
One option is to get the P5 with a traditional cockpit, but the P5 is so tall I don’t know if I can get low enough on it with normal bars. I guess I could always use a downward pointing stem?
As much as I am a sucker for new bike technology, I find the lack of ability to raise my bars quite troubling. I know you can use another bike to get your fit dialed in…
Actually, I think all you need is another bar and stem. A Look ergostem would probably be a good idea in this case.
It shouldn’t be.
If someone was considering getting one of these bikes with the Arduro bar, I’d highly encourage them to either have a fit they KNOW they want to reproduce on the P5, OR don’t order it until you’ve finalized your touchpoint locations (either through personal experimentation or a professional fitting).
I have this: my P2C with adjustable stem. I’m getting fit on it, riding it, experimenting, etc.
But over the course of a season, or even year to year, people never say “I wonder if I might put down more power if I were up 1cm, let me try it next race”?
IME, the range of bar heights that one can put out equivalent powers is fairly wide, especially if one is keeping body angles consistent (as one should). At that point, it’s all about finding the position that reduces your CdA the most and allows for other race considerations (i.e. being able to look up the road, digestion, etc.). Once you’ve found that, why would you move again?
If someone was considering getting one of these bikes with the Arduro bar, I’d highly encourage them to either have a fit they KNOW they want to reproduce on the P5, OR don’t order it until you’ve finalized your touchpoint locations.
Thats going to be a pretty small market. If we go back to the beginning of 2011 you wpuld’ve eliminated Crowie, Cancellara, DZ, Tony Martin, and I think all three Grand Tour winners. I certainly wouldn’t drop that much on an aero bar without at least being awfull confident that my fit is close, but I’d wager that the vast majority of cyclists that prioritise TT riding fiddle constantly.
I think you’re engaging in a bit of “apples and oranges” comparison here…
Why is it apples and oranges? If World champions still try to refine their positions after winning top level races, when they had tons of resources to help get them to a perfect fit during their careers, why do you think amateurs should be able to settle on a perfect fit and not have to change?
The thing is that days good enough for field testing are very rare. I had 2 days in 2011 that were good enough. There were 2 other days I thought were good enough, but turned out not to be when I examined the data afterwards. So there’s a limit to how quickly I can make progress on optimising my position. I got a couple of aspects fairly well nailed down last year, but have more ideas for improvement.
What if a new helmet comes onto the market that you want to try? It might change your optimum position compared to your existing helmet.
What if you want to try shorter cranks, and need to raise your saddle up, and hence your pads to keep your optimum position?
I can see what they were aiming for - the Speed Concept arguably has excessive adjustability, and it places some bulky and unaero shapes at the front of the bike. But I tend to think you could arrange a method of raising the pads and extensions up and down together, independently of the base bar, without adding all that bulk that the Speed Concept has.
Why is it apples and oranges? If World champions still try to refine their positions after winning top level races…
It’s apples and oranges from the standpoint that you’re comparing folks who are basically given and told what to ride vs. someone making a conscious decision about a piece of equipment they’ll purchase with their own funds. I’m thinking the latter will be less likely to have to make “adjustments” or compromises to the position they want to re-create.
…when they had tons of resources to help get them to a perfect fit during their careers…
And I believe in the above cases you mention, those changes were AFTER they took advantage of those resources right? Be it wind tunnel testing or “fitting”, right? OK, so I’m glad you agree with my assertion above
I think EVERYONE can get themselves into a position which is in a “sweetspot”, i.e. where minor changes from that position will have little, if any effect on their speed vs. power. The “perfect position” for anyone has a bit of “squishiness” to it, where 1cm here nor there really doesn’t change things IMHO.
One thing I think a LOT of people get caught up in is chasing power at the expense of speed…and sometimes the pros (and their handlers) are the worst at this. <Cue examples of Eddy Merckxx constantly fiddling with his seat height…or, Armstrong (and Ferrari) rejecting the Trek “narrow bike” merely because his power was lower over long intervals, despite actually being faster>
Besides, constant position fiddling is probably more a symptom of OCD and/or ADD than anything else
That’s not the case for me, moving up or down 1cm from my optimum position is 7W in one direction, and 10W in the other. I think once I get away from that position there is massively less change per cm, but at that crucial tipping point it seems to be very sensitive indeed to tiny changes. And don’t even get me started on the difference one degree of saddle tilt can make, that’s what I need to nail down when I next get chance to test, but I believe it’s pretty massive for me, as it affects how high up the peak of my back is.
I think you’re seriously overestimating the percentage of triathletes who have the optimal position figured out to the point that it won’t ever change. I’d say it’s a minuscule group… not just the newbies.
Of course you can change it, buy buying a new fork… Maybe the solution is just to have a quiver of forks! Or start a fork-swap program here on slowtwitch!
No. The solution is to follow the advice in my first reply.
The whole point I’m making is that “don’t order it until you’ve finalized your touchpoint locations” reduces the target audience to a tiny demographic. Do you dispute this?
Not that there’s anything wrong with designing something for the hardcore experienced folks and pro’s. It’s combining it with a design that allows riding in a position similar to that of a hybrid that makes it slightly more head scratching.
yes because you can use any bar you want.
this is a downside of the Aduro, not of the P5.
furthermore I will bet a few pesos that some armpad risers are or will be available (or that you can use some existing 3t ones) to do adjustments anyway.
I was referring to the Aduro itself, but yeah I agree.
Yep. I was thinking this. And I could imagine 3T potentially making a different riser thingy eventually to be in between the low and high…
I think you are underestimating the number of Pro riders who keep their positions the same during the year. Small body changes, such as weight loss/gain, flexibility, as well as different courses may lead to a change of position for even the best riders in the world.
For example, there are quite a few guys who will change up their position slightly for the Redlands classic TT. Raising the bar a CM or so to allow for a slightly better climbing position. Protour riders have done this as well in TTs with a flat section mixed with a serious climb.
An interesting aspect to the bars and their design…this is from the 3T press release re: the Aduro bars.
Both Cervélo and 3T have extensive experience of wind-tunnel testing for product development. The new bar was shaped by further research into the best aerodynamic posture for riders. This showed that in the classic position favored by almost all solo riders against the clock, the greatest aero advantage was either when the elbows rest on the basebar, or when they rest at 5 cm above the basebar. Intermediate positions, and higher positions, increased drag and slowed the rider.
Looks like I am gonna have to dump the Vision bars that came with my new P2 and put on the Profile T2+ I had on my S2.
(Which I was gonna do anyway…prefer S-bends and I can get lower with those bars)
Wow, interesting! So the “Low” setup, which will likely be most common among those trying to get aero… is the worst!
