Torn between these two bikes. What’s your vote an why?
Bmc, because, well, you can actually get one.
The Scott is much faster than the BMC.
The P5 is faster than the Scott Plasma Premium.
P5 - definitely top notch aerodynamically, has spot for Di2 battery. has UCI legal or illegal options. Aduro aerobar is super integrated and awesome but difficult to adjust if your position is not already dialed in. Don’t have to use that bar though. Hydraulic brakes are pretty awesome, aerodynamically and braking wise.
BMC - EDIT: also has an internal spot for the DI2 battery! aerodynamic palmares a bit unknown but probably good. (As far as I know) - unique looks, integrated brakes difficult to adjust, problematic with wide wheels. Crank has to be removed sometimes to adjust rear brake.
haha, good point. unless you are a 56, then you can get a p5 =)
Get the BMC. Looks better and you won’t be another Cervelo spode rolling around out there. It’s definitely aero enough and the P5 isn’t much faster of a bike. You are splitting nut hairs at this point. Your legs do the work and your positioning on the bike that is key.
There is a 58 P5-Six at my local shop just calling my name… Honestly I think they built it to taunt me into buying it. If anyone is looking for a P5 in 58, ping me. I can put you in touch with the shop.
Oh good so you have seen a yaw sweep comparison of both with a reasonable testing protocol?
Please do post it!
Please do post it!
Listen here Mr. Cervelo lover, who gives a crap. The BMC looks better and being on the P5 isn’t much faster, you are splitting hairs. That is my opinion. So take your biased ass yaw sweep comparison with “reasonable testing protocols” mumbo jumbo and shove it up your ass. I’m just talking shit by the way, but seriously. I ride a SC and could give too shits about a P5. I’m not going to be any faster because of the bike, its just hype and wasted money…I learned the hard way being ignorant when i laid down all the cash for my SC. Now confidence is another thing if you think you are on one of the fastest bikes I’m sure it helps some. I would have rather bought a cheaper bike and focused on being more aero in the cockpit and strengthening my legs. So back to the BMC or P5, get the BMC it looks bitchin. Is all about the rider, not the bike so get what looks sick.
I changed from a QR Cd0.1 to a BMC TM0.1 and my times dropped quite a lot straight away. Dropped about 12 minutes on my IM split on a comparable day year on year (4.50 to 4.37).
If you are going to go with the BMC, get it with Di2 because otherwise the shifting is going to be TERRIBLE. When the cover gets placed, it pushes the cables into pretty awkward shapes and results in some pretty wonky shifting. The brakes are a nightmare with this bike however.
The P5 shifts a little nicer and has better brakes. I only have 2 concerns about the P5: (1) Actually getting one and (2) Adjusting your fit. The Aduro bar is VERY nice, but if your fit is not dialed in properly, small adjustments can be troublesome.
Check with your shop on the availability of the P5 and see if you can actually find one. If you can I’d highly recommend buying it.
There’s a reason why so many Cervelos are in the transition.
Its a good brand.
And if you’ll *"*be another Cervelo P5 spode rolling around out there" despite the price & delay…
It must be a great bike.
Not trashing the BMC,love its new clean fork.
But as you said…its your legs.
Guy riding a speed concept pretending to not care about aerodynamics…
classic!
so spending money on your speed concept prevented you from focusing on being more aero in the cockpit and strengthening your legs?
does it cost money to strengthen the legs??
You might be right that the difference between the BMC and P5 is small. I just don’t know yet.
Please do post it!
This would imply a 260 gram difference in drag between the QR Cd0.1 and the BMC which is probably impossible. unless the QR is really bad, and I Doubt it is. If you had power files and exacting setup sepcs that would help the analysis a lot
260 gram difference
Must report in CdA, come on!
classic!
Please do post it!
LOL, duuuuude. If I had to do it over again I wouldn’t have bought my SC…it was my first Tri bike (I’m retarded what I can say). It’s a nice bike, but I got a 9 series and I spent too much money. I would say spending around $5k would have been better for me and guess what I wouldn’t have been any slower. Oh well, live and learn. I still spent time focusing on getting aero in my cockpit on my SC regardless and strengthening my legs was free (training a lot on the bike with a good plan). You’ve taught me some things about being aero, so I respect your opinion. However, you will always be a Cervelo lover, which is fine too. Later
The shifting on the front end of the TM01 is very finnicky… A couple nice tips are to run the Bontrager RXXXL brake levers as they have the integrated barrel adjuster on the end of the lever. Also use nokon with the smaller beads for the rear d for any super tight kinks for the front end shifting (or aztec, etc)
Ive had my TM01 over a year and have never had any issues with shifting performance. Shifts better than my P2 did.
Yes I was surprised it was so much faster too. I thikn the seat post clamp on the CD0.1 was always wobbling and causing lost power. I only got a power meter with the BMC so don’t have data from the previous year unfortunately
