Wrote this review a couple months ago, and finally got around to posting it ![]()
My new P4…
After years and years of using the old Alu Soloist as my TT rig, I finally broke down and sprung for that P4 in the LBS window. Is it a coincidence that I keep typing P$ when I mean to type P4? Perhaps a subconscious slip, or just holding that shift key slightly too long.
Pricey yes, but this thing is feels fast and I was ~kinda~ able to verify its speed.
The Good:
My local 10km rolling practice loop allowed for the best comparison I could manage. I am lacking a powermeter in my current setup, but I have rode this loop perhaps 50 times and time it precisely each time. I tested with the same kit, shoes, helmet and 404 clinchers as my Soloist. Results: best Soloist laps typically are ~ 14min 30 seconds at 90%+ effort; the P4 could consistently lop 15 or so seconds off each lap (for a new course record, for me). Needless to say, I was very happy with this. Interestingly, I also set a new best time on the shallow ascent of Spanish Banks hill. It was only by a couple seconds, but I was pleasantly surprised to have any improvements hill climbing on my TT bike. The frame is very stiff and transmits some road vibration, though is still softer feeling than the alu Soloist.
Like the skinny rotor cranks, very cool.
The front brake hangs out in space, but apparently its the rear aspect of a foil that is most important in determining aerodynamics. In this respect the bike is great, all tubes trailing edges are smooth.
The Bad:
Rear brake
Though faired beautifully in the bottom bracket - minimal stopping power, at best. Remove crankset to adjust, change pads. Wheel swaps could be quite troublesome! The price we pay for speed?
The bottle
Crazy hard to put back in when you are working it. After several attempts to put back, the sharp edges of the cage had wore grooves into the thin plastic bottle because it wasn’t *perfectly *aligned. After each unsuccessful attempt to put away, the grooves get deeper and making the bottle more likely to misalign and thus harder and harder to put away. I think this issue could be easily fixed if only they made the bottom edges of the bottle soft, so it would self align better when you try to shove it back (blindly) at 50kph. The bottle is wicked aero, and for me, was a convincing feature of the bike. For safety and reliability I have now had to change it out to an Arundel Chrono, this kind of irks me. I’ll pray for a redesign…??
The Neutral:
Cockpit:
Would like a sick aerobar/extension setup from the start. The big ski jumps stick way up, especially with Red shifters on the ends. Plan to swap out and find the ‘perfect setup’. Pro missle evo perhaps is what I’m leaning towards right now.
Also regarding aerobars, I often whack my knees on the 3T Aura bull horns whenever punching it on a hill. Stem length is perfect, wouldn’t want it longer. This might happen with all aero bullhorns I suppose… Prior to this my only experience is with the Soloist drop bar and clip on T2s.
Price
Somewhat bad, though I got a end of season deal from local shop speed theory. However, I think prices will continue to drop on remaining stocks as I believe Cervelo’s next world beater will be released sometime next year.
Overall: 4.5/5… so far. More updates to come with further testing and front end changes + wheel upgrade?
