P3SL vs P3C Geometry
I know the geometries changed a bit when Cervelo went to carbon. Does anyone know where I can find the geometry for a P3SL online? SPecifically, I am looking for stack and height for a 55cm P3SL.
My sense is that the 56cm Carbon has a significantly higher stack and a slightly shorter reach. Is this true?
Thanks,
i think in general the carbon versions had a longer top tube in corresponding size, with stack remaining mroe or less unchanged.
This eBay auction has the P3-SL geometry listed:
http://cgi.ebay.com/...31&rd=1&rd=1.
Now I am really confused. I thought the carbons had shorter top tubes and taller stack heights.
I have surfed around a bit and cannot find the geometry charts on out of date cervelo bikes. The web is failing me here. If anyone knows were to find this info, please point me in the right direction.
Thanks,
Thank you. ebay … the new source of truth.
I don’t know if this link will work but you can find the same tables here:
http://web.archive.org/.../P3-SL.html#Geometry.
The old geometry in the Knowledge base in the Engineering section of our website.
