“Did you ever ask the designer (gerard, et al.) WHY he designed a reversible seatpost head for his TT bikes?”
of course i have. we talk about geometry all the time, and have been doing so for probably 5 or so years.
gerard does this for the converse reason that kestrel designed it’s two-headed aero seat post that goes inside the seat tube of its talon. it’s to allow people who want to ride THAT SPECIFIC frame to ride it in a way for which it’s not optimized.
the talon is optimized for road geometry riding. it’s a road bike. but it’s got a facility allowing it to be ridden steep. that’s fine, as long as you realize that it’s not optimized for tri riding, and as such i say, why not just buy a bike optimized for tri riding instead?
the p3/p2k/dual is in every dimension optimized for riding with the clamp forward. sure, cervelo did what kestrel did, and arranged for users to ride it in a way for which it is not optimized.
but, when you go back, you also go up in front, and back in front, that is, the h’bars must be positioned higher, and rearward, to accommodate. that’s why the cervelos have -17° stems, so that if you flip the seatpost back you flip the stem up, such that you’ve got a 5 am woody on the front of your bike holding up your h’bars.
the problem is, it’s hard to adjust this h’bars fore/aft with this woody. much easier to put a 5cm, 6cm, 7cm, 8cm, whatever, -17° stem on the bike. but, then, you need 7cm worth of spacers under the stem. this answers the question the other poster made, which is, why is it so many cervelos have so many spacers under the stem? no, it’s not that cervelos head tubes are too short, it’s because people are basically making a semi-steep road bike out of a tri bike.
it’s easier just to slide the saddle forward on a talon, a madone, a soloist, or p2.5, slap aero bars on it, and go. trying to rig a p3 to be riddden at 74° or 75° is silly. but worse than that, most dealers haven’t even thought this through. they just set up the p3 with the clamp back because it looks more normal, and that’s a REALLY f^*king lazy approach toward retailing, if you ask me.
