P3 & Kuota Kueen-K size info
Hello,
I’m shopping around for a new bike, still debating between the P3 or Kuota Kueen-K.
I own a Felt S32 size 54. I’m 5’11 / 180lbs
what size would be a “good fit” for the P3… 54 or 56 ?
How about the Kuota? M / L / XL ?
Anyone out there that owns one of these 2 bikes with my size can help me?
Thanks
I would strongly recommend against using the supplied “size” across manufacturers. Compare the geometry tables for exact dimensions. If you’re just wanting to duplicate the fit, this will be more helpful.
I’m 5’10" and own one of each of those bikes. I have 54 P3 and a medium Kueen K… I have a long torso for my height(probably why I ended up a swimmer), so I get my bikes to fit that dimension more that leg lenght. If it was just leg lenght, I would have gone with a 52 P3…
Look here for a more side by side comparison.
http://www.slowtwitch.com/stackreach.html#Anchor-KUOTA
http://www.slowtwitch.com/stackreach.html#Anchor-CERVELO
Dang Dude, are you serious? That is a lot of cash put into your stable! So, just curiuos, what are your thoughts with both bikes? Which do you like better and why? I personally think the green kueen K is the best looking bike out there.
it’s pretty clear that he means P3 and not P3C. P3s are not that pricey these days.
Ya, my P3 is of the old alumnium version, so I have had it for several years. The KueenK I just got, so I can’t give you a good comparison, but so far I like the carbon component of the frame, and the fact that I can go very far foreward on it without any aftermarket gizmos… I like to ride at 85 degrees+…
duh, good point. But, still a nice set of bikes to choose from.
