P-Series race set up guidance
I would like to get some feedback. I have just purchased a 2023 Cervelo p- series for an attempt at 2 Ironmans this year. There are two items I would like to upgrade on the bike and need some guidance. I have been out of the triathlon scene for a long time and feel lost.
  1. I would like to upgrade the cockpit with the goal of comfort, aerodynamics and a BTA set up. What are my best options?
  2. I would also like to upgrade the wheelset. My preference is as fast a wheelset as possible with my preference being a hooked rim that I could run either tubeless or with a tube. What are my best options? Thank you for any guidance and have been looking and feel overwhelmed.
  1. Since it has a standard headset, you have a wide variety of options. I went with TriRig on mine but I have mixed feelings about it after a year of use.
  2. Offhand, I’ll suggest looking at Hed, Premier Tactical, and Parcours for what you described.
What didn’t you like about the tririg?
Bang for buck, then the Trek Aurelus RSL 75 wheels are very hard to beat. Light, stable in crosswinds and very cost competitive, with a bonus that you can get with local bike shop support in case of any issues. Hooked and tubeless as you (wisely IMHO) want. And whilst many will say you want a disk, and I wont argue, this gives you a wheelset that will be quick and useable in pretty much all conditions.
What cockpit is on there now?
What wheel/wheelset?
Without those necessary bits of info it’s hard to make accurate recommendations
You didn’t mention BTS hydration, but for Ironman racing I use B-RAD double bottle adapters on the stock rear bottle cage mount. You can get two bottles BTS, and also use a B-RAD mounting base if you want to adjust the height of the bottles.
Double Bottle Adapter: B-RAD Double Bottle Adapter – Wolf Tooth Components
Mounting Base: Wolf Tooth B-RAD Mounting Bases - Shifting bottle cages, add tools – Wolf Tooth Components
My P-Series had a Vision basebar so it was a no brainer going with the Vision TFE pro aerobar. Like them alot. Great comfort and adjustability.
The bike has the stock profile design cockpit and dt swiss rim(not deep, almost true box rims)
Thank you. I have never seen those before. That looks like a good option for BTS set up.
I’d look at crw works wheels on pandapodium. Light bicycle also has some good options.
IMO from having fit a lot of people on the Vision’s and Profile’s I’m team Profile 9/7 days of the week. You’re probably fine with what you have, maybe some extensions changes to your favorite shape/angle.
For wheels you can’t go wrong with any of the major brands. Now if you’re going to ask them to do double duty as a training and race set then you may make some compromises as far as depth front/rear.
HED, Premier, SwissSide etc. Most of these wheels are going to be within :10/40k of each other. Of course I’d rather be :50 up to road at the end of the IM bik leg.
What would be your 1st and 2nd wheel choices that are not hookless?
  1. HED Vanquish 62/84 with 28c GP5000 S TR’s.
  2. SwissSide Hadron 62/80 with 28c GP5000 S TR’s.
Those should be great combo training and race day wheel sets. Easy to control front wheel with a deeper rear wheel for stability. Add a disc if you want for race day, or save some bucks and get an EZ Disc cover.
I spent a good chunk of last summer testing tires and wheels. I had a set of Premier and 2 “high end” wheels. They were identical in terms of performance.
I would be looking at other factors such as crash policies, who I buy them from…
I have training wheels and race wheels for one simple reason, race rubber is too fragile for everyday training and no way I am swapping tubeless constantly
