Yes i did a search already and didnt find anything.
Can i substitute my calories on the bike in a long distance tri with orange juice instead of an electrilyte mix? Has anyone tried this? Good or bad idea? Essentially it would have calories and natural sugars. Juat cut it with water, add some sodium and potassium and you are good to go. The reason i ask this is because im trying ro find a was to stop the gut rot bloating with something natural (and cheap). Gels seem to sit heavy in my stomach during exercise.
I think oranges are on the lower fructose side of things, so that’s probably preferable to something like apple juice. You’d have to give it a try and see obviously but it definitely could work if you enjoy drinking it enough (and when it’s warm. Maybe that’s an issue).
The pH of OJ is pretty low. I’m not really sure what if any problem that would cause, but it certainly distinguishes it from regular sports drink. Obviously if you cut it with water the pH will rise, but then it will become hard to carry enough calories, as though it wouldn’t be with straight OJ.
OJ would cause me more bloating, and maybe barfing. Try it in training and see how it works for you. My .02, If you can tolerate whatever sport drink your A race has on the course it simplifies things.
I would first take a hard look at whether you need any nutrition during your training sessions at all. *** If your nutrition is solid when not training***, you can probably get away with just water on all but your long bike rides.
I’ll sometimes have an OJ with me prior to the swim and drink it over the period of an hour or two. But I think I’d find it too acidic and sweet, especially when it warmed up.
I have used it in 300k rides without any problems but I would not recommend it.
I usually use it when I run out of other stuff and wait for sales since it’s pretty cheap. I mix it as 1 part oj 2 parts water and a little mineral salt, doesn’t taste that bad as long as it remains cold.
I prefer oj over other juices cause it doesn’t taste as sweet as others wich makes it easier not to empty a bottle in one go.
