Older Felt Specifications- Where?
I’m trying to find specifications for my 2004 Felt F60 and can’t seem to find anything other than very basic specs(see below). I know Felt used to have a site that gave very detail specs and geometry (I think it was actually the old website from 2004 just achived) that was accessible to the public but don’t know if it still exists. Anyone know if that still exists and/or has the URL?
Please, no “google” comments. Been there, tried that.
Thanks in advance!
Description
Frame Material: Felt Superlite custom 7005 alloy with carbon seat stays
**Frame Angles: **74.0 head, 73.5 seat
**Sizes: **47cm, 50cm, 52cm, 54cm, 56cm, 58cm, 60cm, 63cm
**Colors: **White
**Fork: **Felt
**Rear Shock: **Not applicable
**Brake Levers: **Shimano 105
**Handlebar: **Felt alloy 6061 ergo
**Stem: **Felt 6061 forged alloy
**Headset: **1 1/8" FSA integrated
**Front Der: **Shimano 105
**Crankset: **FSA Gossamer, 30/42/53 teeth
**Rear Der: **Shimano Ultegra
**Pedals: **Alloy Clipless
**Tires: **700 x 23c Continental Sport 1000
Thanks in advance!
Description
**Colors: **White
**Fork: **Felt
I have the detailed spex for this model, what did you need to know?
-SD
SD will probably get you better information, but if you’re curious what the actual published data was back then, http://www.archive.org/web/web.php is a great site to pull up their old website. Some pages and some pictures might not be there (especially on certain years) so you might have to dig around. Also remember their website used to be feltracing.com so search for that too.
How do I know? I was trying to find the geometry of my dear old 2005 Felt F70 while shopping for its potential replacement. Just don’t tell SD it may not be another Felt… :slight_smile:
Thanks SD! I was looking for mostly looking for the specs on the handlebars and stem (size and weight if they are available. Just size if nothing else. I’'m looking to replace them and didn’t know exactly what I had b/c i need to shorten up my reach and narrow m grip on the bars a bit but also want to lighten the bike in the process as much as possible.
By the way, the archive link is AWESOME! It lets me access some old school Felt sites (just didn’t have exactly what I needed).
Thanks much!
Thanks much!
Can you let me know what size you have? The bar width varies by size.
Crap. Sorry dave, thought it was in original post. It’s a 56cm
2004 was the last year the bars were 26.0mm clamp diameters. The handlebar on the 56cm was 44cm wide from c-c with a reach of 88mm and a drop of 149mm. The shape was the traditional ergonomic shape with a small flat section for your hands in the drops.
Regards,
-SD
Hi, I’ve got a 2004 felt f60 in a 54cm size. Do you know what the seat tube angle is? I want to get a new bike and I hate how far back the seat sits on this bike, and i want to compare it against other bikes. Thanks.
sorry, please ignore. I see in the first post is says 73.5 degrees.
