You might be able to just splice the worn wire. I did have to replace one of my sensors. It is about as easy as mounting a toilet roll hanger. But a pain because you can’t use the door until it gets fixed.
Typically you will see something that looks like a Cat 5 cable running into the top of the garage door opener. Individual wires will be coming out of it and going into small openings in the opener. Those are for the sensors and the button on the wall.
Any voltage coming out of those wires and going into the sensors will be so low that it probably wouldn’t even tingle if you licked the wires at the same time. They are basically for “signaling” the opener. You may not want to cross/touch them, but you shouldn’t need to.
You may be able to replace just the sensors as long as they are compatible with your opener. Unless they are new, you would need two new ones.
Meaning the wires running to the sensor are low voltage and have less umph than a 9V battery. It’s one of those things that an electronics teacher in school would have to you turn off the breaker (or unplug the opener), but your dad would just say go for it.
Wet your fingers and touch the exposed wire. If you don’t respond in 24 hours then it’s line voltage.
It’s not line voltage as sensor wires are anywhere from 12 to 24V and shouldn’t shock you. If you don’t feel like shutting power off then just wear some garden rubber gloves.
Okay. Now that we’ve fooled him into thinking it won’t hurt him, who’s going to go to his house and record video of him getting shocked and peeing in his pants?
j/k - Compare the difference between the size of the wire running into an outlet versus the ones in the sensors. The wires on the sensors are often a small single-strand wire because they don’t carry much voltage.
If I remember correctly, I think they (the National Electric Code, the code making body flof the NFPA that oversees electricans) say 48V and below is safe to touch.
In the controls world, mostly what we use is 24VDC, but typically something like a garage door opener or a doorbell or anything along those lines will be 24vdc, 24vac (still won’t hurt ya), 12vdc, or occasionally 5v (rare, but I’ve seen it, albeit years ago).
My apologies: I forgot who I was talking to.
Sometimes things don’t translate well in this medium, as we all know, but the above was not meant as a dig, more like a light-hearted jab. Lord knows, if the roles were reversed and I had a finance question, I’d look like the ignorant bumpkin.
…Oh, wait: that’s also because I am an ignorant bumpkin… but you get my point.
Also, these are a helluva lot more fun than another political thread…
In my early bicycle building career, my “workshop” was in our garage
The garage door would go up & down by itself (we didn’t have a door opener and I’d never hear it move; I’d turn around an it was open if I’d closed it, or closed if I’d opened it) , the back door and side windows would open & close, tools would fall off the table or slide across the floor, but most disturbing - to me, personally - was that the radio would change stations on its own. I’d be cranking along to Led Zeppelin or Van Halen, it would zip over to the easy listening station and suddenly there’s Barry fucking Manilow
We always thought the guy who killed himself in our house did it in the basement. Our dogs would never go down there, you always felt someone was watching you. We tried making it a “fun room” with pool table & ping pong, but there was absolutely no “joy” down there, and we always gave up in the middle of a game
However, we found out later, that he had actually hung himself … in the garage
