Jay, what about a longer bento box which stretches further down the top tube?
Hello,
I own a Speedmax CF Di2 from 2017 and have been super happy with it in Races. The fit is perfect. However recently the cockpit has been bothering me more and more. I mean the cables from the bar to the di2 Box, the non-integrated aero bars etc.
Have some of you addressed these issued with rebulding the cockpit? For example with an Aeria ultimate stem and base bar? Or in any other way?
Or just get a new integrated frame?
CanyonJay is it possible to mount my Wahoo Elemnt Bolt on my hydration unit? Jan has it
I switched from Garmin to Wahoo but the wahoo doesnāt fit
Hi Guys,
Really struggling with the fit of the CF before ordering.
The size guide puts me on an XS - just sounds wrong to me.
I usually ride with my saddle around 720 from the centre of the BB.
My road bikes are always small or 52cm ish.
Iām 5 foot 6 - longer legs, shorter arms and torso.
My last bike, a Dolan Scala, fitted really well with an 80mm stem and the saddle all the way forward, but Iām struggling to compare the measurements.
Just need someone to look at them both and say yes, an XS is correct!
Thanks,
Pat.
Pat,
The last bike of which you speak, itās a tri bike, right? And are/were you comfortable on that bike? Would you want the new Speedmax to fit pretty much the same way? Iām asking because I can walk you through a pretty simple process of measuring the Pad X and Pad Y of your current bike and then we will KNOW - not only what size is right (if itās the XS or the SM)ā¦andā¦specifics on the front end set up.
Let me know, Ian
Hi Ian,
Yes it was a tri bike and it was Ironman comfy.
Unfortunately itās now gone so I can only estimate the dimensions.
The only dimensions I kept were my saddle height (720mm), the distance from the nose of the saddle to the stem cap bolt (420mm) and stand over height (740mm).
Thanks,
Pat.
Iāve since played with the Canyon PPS and for my height, my torso and arm length donāt affect the size. Itās the inseam length that makes the difference. Iām about 81cm which puts me on a Small. If it was 79cm, it puts me on an XS. Isnāt the consensus to go smaller on a TT frame? Saying that, Small might give me the best options as it comes with an 80mm stem so I can go a bit shorter or longer does that make sense and that I should order a small?
Hi Guys,
Iām 5ā11" and ride a medium and should really be on a small frame. At your height a xs sounds correct.
To answer your question directly, if both an XS and a S will fitā¦the bigger bike would perhaps be better for handling (considering the wheel base, front center, trail, etc). butā¦hold onā¦Iām hoping you have the patience to work through this with me.
The PPS is good. But knowing your Pad X and Pad Y is best.
Get your existing bike level: the best bet is to put in on a trainer with a wheel block under the front wheel so itās level - but you could just lean it against the wall (on a level floor) so that the bike is as straight up and down as possible. Iām going to ask you to measure a couple of things and to do this most accurately youāll want work on the non-drive side.
Measure from the floor up to top of your arm pad. Then measure from from the floor up to the center of the bottom bracket. Do the measurements a couple of times and get an average. Subtract the BB (bottom bracket) height from pad height. If youāve doing this in inches then please go here and convert to millimeters. This is your Pad Y (also known as Pad Height).
Now, we need to find Pad X (aka Pad Reach). To do this you might need a hand from a friend or family member. Have them dangle a plumb line through the center of your BB (so they can hold it near the front of your saddle and then you can crouch down and guide to back up a hair or go forward a touch to get it dead center on the BB. Then measure from the plumb line to the back of the pad and to the center of the pad. Iād like to know both please. Convert this number to mm and youāll have your Pad X.
Get back to me here with your Pad X and Pad Y and I can confirm your bike purchase.
If you have questions hit me back and Iāll solve it.
Ian
Pat. Hold tight. I can math out from saddle height and come up with a pretty good number. Iāll get back to you ASAP.
Ian
Thanks guys.
Hereās a pic of my last TT bike.
I have a Wattbike Atom so could loosely replicate any given dimensions to try.
Thanks,
Pat.
Indeed, itās possible, but Jan (as well as Team Katusha-Alpecin, as I noted on their bikes at Tour of California) cncād Wahoo Bolt inserts. We only offer a Garmin insert (given the brandās sheer popularity/volume) those inserts would have to be a Wahoo product. Iāve meant to reach out to them to find out if they will be making an insert that will work⦠lemme get back to you!
Update: Wahoo does now make an adaptor, allowing use of a Bolt on a Garmin bracket:
https://www.wahoofitness.com/devices/accessories/quarter-turn-mount-adapter-elemnt
https://www.wahoofitness.com/...mount-adapter-elemnt
Jay is there a Canyon GPS mount made for our CFās? I know there is one for the SLX but not sure if there is one made for the CF
There is not for the CF. Being a standard 31.8 basebar (or a 22.2 extension), there are too many good computer bracket builders (K-Edge, RecMounts, BarFly, Zipp and Garmin typically provides their own with computers, etc.) for us to produce one.
How or where do you guys buy adaptors for you speedmax cockpit? Does the bike come with a set of different angles and stuff?
Thanks!!
Morning,
Iāve just purchased a Speedmax CF and am wondering if anyone elseās nutrition box sticks out and if so what adjustments were made to get it back behind the saddle post? Due to the 3 wires coming up through, mine bulges out the sides which obviously wont be great in an aero race.
Thanks
Any insight as to when the Speedmax WMN CF 8.0 LTD will be available in XS in the US? Itās showing available on the European site.
If youāre looking for Speedmax SLX adaptors, at the moment the best way to get them is to call in; we havenāt yet updated the website with many small parts, so whether itās rear bottle brackets (which we had a limited supply of at last check a few weeks ago), angle wedges, switch plates, etc., itās best to call 833.226.9661 and ask for the pieces you are seeking. The bike comes with spacers in 5mm increments that can stack up to 80mm high.
Weāre scheduled to have a limited number (five) models hit the website the last week of this month⦠in just under two weeks. Check then, but be sure to sign up for email notification, and youāll get an email when the XS is live and in stock on the site!
