My baby! My first race on her and after a change to the extensions. Maybe we should merge these threadds? https://forum.slowtwitch.com/forum/Slowtwitch_Forums_C1/Triathlon_Forum_F1/Official_Canyon_Speedmax_CF_SLX_Thread_P6650725/?page=unread#unread
From Alcatraz this past weekend for me!
are there Di2 shift buttons on the bars as well as the extensions on the CF 8.0? I get mine tuesday and wondering what upgrades i will need to do!!
Speedmax owners. Curious as to how many spacers you have on bars? (From basebar to extensions)
I have 2x2cm + 2x0.5cm and the tilt spacer. In total itās 6cm from the basebar to the start of the extension mounts.
what are people using for a rear hydration set up. Has anybody found a good mounting bracket for the seat post screws?
Iām going to get a Canyon rear bottle holder, issue is theyāre not available till Aug or laterā¦
Yep theyāre buttons on the bars but they can only control your RD.
Ok so fill me in on your hydration system. My speedmax gets delivered on Tuesday! I really want something like the slx has.
Currently using 2 Gorilla cages on the bottom, I just upgraded to the PD Ultimate Steam and am waiting for delivery of the PD Aeria Hydration system which may not arrive till end of the month. UGH.
Iām only running one bottle behind the saddle. But made a neat and cheap solution by drilling an extra angled hole in a sturdy plastic cage and zip-tie the top of it to the saddle. Its rock solid and lightweight!
I bought this one for my Speedmax. I just called Canyon for the gazillionth time and they still donāt have an ETA for the bottle holder.
It fits well. Not ideal and certainly not fancy, but it gets the job done. https://www.aliexpress.com/item/Bike-Saddle-Holder-Adapter-Double-Water-Bottle-Back-Bicycle-Double-Water-Bottle-Holder-Cage-Adapter-Rack/32832763154.html
0
Im assuming the hole you drilled matches up with the seat post screw hole for the bottom?
I called Canyon and they said August for the rear mount. I was just looking for an option for next weekend lake placid.
Yes. Made the hole by eye measurement and used the drill to increase the hole diameter vertically for extra adjustability. But since the cage is plastic, its quite flexible. I put a 5mm spacer and a piece of old tube (for scratch protection) between the seat post and the cage
Iām looking at ordering one of these and would like to know from existing owners how easy it is to remove the stem and bars for packing into a BikeBox Alan for air travel. In the photo the cables all disappear into the top tube storage box. Do you need to remove the box?
I am also looking at the new 2019 Boardman ATT 9.0. One difference I have noted is that the Canyon chainstays are 20mm longer @ 420mm and the stem is 20mm shorter @ 90mm. The Canyon wheelbase is also 20mm longer @ 1037mm. This is for the large size, I am 188cm tall. Would I be right in thinking that this might result in the Boardman being a bit more twitchy / responsive and the Canyon being more forgiving and less stressful on technical courses?
Both bikes are mail order only, so a decent test ride is not an option. The 2017 Boardman got very good test reviews for itās ride and handling but havenāt found any tests / reviews that compared the two against each other.
This will be my first Tri bike, my main bike is a Canyon Endurace with disc brakes. I live in the Scottish Highlands, so the roads are quite lumpy, hence my concern about handling, particularly on steep descents.
Hi, I have 2018 Speedmax CF 8 and did two airtrips already. Preparing the bike for the fly and putting back together is piece of cake. Just have some carbon grease with you and you are all set.
Sizing Question
trying to figure out that correct size for the Speedmax CF (Not the SLX!). Maybe you can help ![]()
Bike-fitter of trust specced my long-leg, short-torso, stone-like-flexibility into:
Saddle Height: 775mmArm Pad Stack: 710mm (make sure to stop laughing after 5minutes to avoid injury!)Arm Pad Reach: 470mmSaddle setback: 0mm (from tip of saddle to center of bottom bracket)Drop to pad: 60mm (From saddle to top of pad)Drop to bars: 120mm (From saddle to top of bar)
So best as I can tell, I can go with either a size M or a size L, both seem compromisy:
Option A Going for size M
Saddle height is within the rangeArm pad reach can be hitArm pad stack is 18mm outside the spec
So from how I understand the āProfile Design Riser Kitā I could extend this towards 70mm and hit 702mm, which is almost there. Some stretching then ![]()
Option B Going for size L
Saddle height is at the total minimum, which is exactly 775! (Makes me super nervous)To hit the arm pad reach I have to get my hands on a 70mm version of the stem (didnāt see it in store)Arm pad stack is within the spec (No extra risers needed)
Questions:
Am I somewhere off, any misconceptions on my sides?Did anyone measure the a real bike against the geometry chart? Is the geometry spec from Canyon a promise or more of an estimation?Anyone experience with high riser setups (for M size)? Is it still comfy to get to the bars then?Anyone experience in getting a shorter stem from Canyon?Anyone put in some other (cheap) non-Canyon to increase stack/decrease reachWould you run with the L being at total minimum height? Change in saddle, cleats, shoes could skrew me up heavily.
Iām concerned that there isnāt enough exposed cable to move the bars very far away when the stem is removed. The cables look like they are ziptied to something in the energy box, which is why I wondered if you need to remove the box?
I know with my Road bike that the handlebars need all the slack cable to be able to fit them in a secure position in the box.
My LBS got my cables pretty far away into my basebar. Iām riding a 110mm stem.
Also, Iāve flown with my bike 6 times already and no problem. Super easy to take apart and put together.
Iāve found that I can ride my CF almost like my road bike (Boardman Air Elite 9.8). I live in a very hilly and twisty area, and it handles very well.
Three is enough cable (on my 80 stem) to put in on the side of the frame and secure. But be sure to put some sponge or buble plastic so the bar doesnāt skratch from the frame.
