Hey yall!
How are you storing your boots? Hanging them on the hooks or what?
Also, is it safe to roll up the Normatec boots up? I have an older version so they are kind of stiff.
Is there a travel bag that works?
These:
Hey yall!
These:
I just toss mine in a duffle bag.
I wouldn’t roll up them. There is a proper way to fold them and I asked Normatec at one point to make a video of it but I don’t think they ever did. Normatec has the hardshell case for traveling. I do find when I just rolled them, which was easy to squeeze air out for travel, that some of the bags got a bit wonky - like were not inflating to correct pressures. I ended up sending them back to Normatec and doing some diagnostics on them but they ended up being fine in the diagnostics. Since then I started being more careful with travel and folding instead of rolling and haven’t noticed the same problem of some bags not inflating correctly.
Regardless, this is one big benefit of the newer 2018 Normatec Pulse even over the older 2015-2017 pulse and the MVP you have. They have made the boots stronger and doubled the warranty as result for the 2018 version. I covered some changes between the 2015-2017 Pulse and what I call the Gen 2 2018 Pulse here.
Using my boots as I write this, I use the Normatec Carry Case…
