Not sure if this had been released (in part) previously, but it seems as though a research group has just published some actual data into the efficacy of the Nike Zoom Vaporfly 4% shoes that were used in the Breaking-2 attempt. Certainly an interesting read and gives some insight into the 4% claim:
To summarise my additions in red]:
18 high-caliber athletes ran six 5-min trials (three shoes × two replicates) in prototype shoes (NP) seemingly an early Nike Zoom Vaporfly 4% prototype], and two established marathon shoes (NS Nike Zoom Streak 6] and AB adidas adizero Adios BOOST 2]) during three separate sessions: 14, 16, and 18 km/h approx. 4:30, 3:45 and 3:30 min per km]. We measured submaximal oxygen uptake and carbon dioxide production during minutes 3–5 and averaged energetic cost (W/kg) for the two trials in each shoe model.
Compared with the established racing shoes, the new shoes reduced the energetic cost of running in all 18 subjects tested. Averaged across all three velocities, the energetic cost for running in the NP shoes (16.45 ± 0.89 W/kg; mean ± SD) was 4.16 and 4.01% lower than in the NS and AB shoes, when shoe mass was matched (17.16 ± 0.92 and 17.14 ± 0.97 W/kg, respectively, both p < 0.001). The observed percent changes were independent of running velocity (14–18 km/h)
Interesting. The slow pace is 7:15/mile and still was 4%. There was some speculation in the other thread that these shoes weren’t that efficient, and in fact possibly a hindrance, if you were running slower than 7/mile.
IIRC those complaints centred around foot cramps, possibly due to the increased sole-stiffness? Worth noting that the test period here was only 5 mins long and would not have been influenced by issues like those. It seems as though you can still benefit from them at speeds that us mere mortals might run at, so long as your feet can take it.
It’s annoying because I don’t want to spend anywhere near that kind of money on shoes, but I’m sure someone I know will!
I seem to recall someone mentioning Rupp running in a similar shoe once, but I presume it didn’t have the same sole-construction, because as discussed at length around the time of the Breaking-2 attempt, it would seem that they would be expressly forbidden under current IAAF regulations. I would presume the big shoe companies are lobbying them hard to relax the rules and allow shoes such as this in competition.
Rupp won Chicago and Shalane won NY in the 4%. The ones they used at the breaking 2 event were the “Elite” version that don’t any rubber under the heel. I don’t know how different they are other than the rubber missing from the heel for weight savings. They both have the carbon plate, but I don’t know if it’s the same plate.
Interesting, well that shows how much I know about these things!
Looking at the rules, it seemed as though the carbon-plate was the main issue for potential IAAF non-compliance, but I guess if people are using them to win IAAF-sanctioned events then they must have been ruled as compliant.
I just looked at some specs of that Zoom Vaporfly. Looks crazy thick with Hokalike stack, but Nike managed to get the weight down to a scant 6.9oz, which is impressively low. Makes me wonder if these runners would go even faster with less stack/lighter shoe, but as is can’t argue against their excellent race results with this shoe.
It is the same carbon plate in the Elite and 4%. The Zoomfly has the carbon infused nylon plate, which is different than the Elite & 4%.
The difference isnt just the rubber on the bottom. The entire shape, material, design, and placement is different on the Elite, as well as the upper. Same cushioning though (ZoomX) in the Elite & 4% while the Zoomfly has a form of Lunarlon.
The Elite has only been available for sale in limited quantities. 100 units available by raffle, for the opportunity to purchase, in both London and New York. We may see something similar in LA for the LA Marathon.
Out of curiosity, I looked at the Zoom Vaporfly 4% on Nike’s site. They say the drop is 10mm?! This must be a shoe for heel-strikers only, unless I’m missing something. I anything over 5mm and my heel and ball hit at the same time, which throws my form all to hell.
Do you know how the durability of the shoe is, then? I’d be willing to try it, but if I’m only getting 100 mi out of the shoe versus 250 then it’s not a possibility.
Depends how you strike but there are reports of shoes from people having 500 miles on the Vaporflys. Heel strikers seem to wear through them more quickly but they are still seeing 250+ miles out of them.
I went back and found my post from the original Breaking-2 thread where I dug-up the IAAF rulebook and to copy it here:
**Shoes **
2. Athletes may compete barefoot or with footwear on one or both feet. the purpose of shoes for competition is to give protection and stability to the feet and a firm grip on the ground. Such shoes, however, must not be constructed so as to give an athlete any unfair additional assistance, including by the incorporation of any technology which will give the wearer any unfair advantage. A shoe strap over the instep is permitted. All types of competition shoes must be approved by IAAF.
**Inserts and Additions to the Shoe **
6. Athletes may not use any appliance, either inside or outside the shoe, which will have the effect of increasing the thickness of the sole above the permitted maximum, or which can give the wearer any advantage which he would not obtain from the type of shoe described in the previous paragraphs.
I appreciate that wording is vague (and probably deliberately so) but surely Nike have just *proven *that their shoes are non-IAAF compliant?!
**Shoes **
Just to follow up on this, even though I’m seemingly the only one who cares… I was (very) bored over lunch, so I checked the latest IAAF Competition Rules and Regulations and it appears that the “incorporation of technology” clause on shoes (highlighted above) has been cut out since I quoted it last time. It still leaves the rule ridiculously vague (and again, probably intentionally so) but the change to the wording would perhaps give Nike enough wiggle room with the Vaporfly?
So, it would seems as though the IAAF are happy to allow them… the start of a quiet revolution in modern running shoe design?
“The Vaporfly prototype they tested returned 87.0 percent of the energy, compared to just 65.5 percent from Nike’s previous state-of-the-art marathon racer, the Zoom Streak 6. Interestingly, they also tested the Adidas Adizero Adios Boost 2, which was used by Dennis Kimetto to set the current men’s marathon record of 2:02:57. It returned 75.9 percent of the input energy. The authors note that versions of these two shoes (the Streak 6 and the Boost 2) had been used for all ten of the fastest marathons in history at the time the study started, in April 2016.”
When a pharmaceutical sales rep comes in my office and shows me his/her company’s brochures indicating why their product is better than anyone else’s, I get suspicious. This “study” was funded by Nike. Did you expect to see any other results? First thing to do before reading a scientific study is to consider the source.
Being a research scientist myself, I’m well aware of the concept of “conflict of interest”; I did check the declaration statements at the end of the paper before posting, hence my choice of words in this thread title: “Nike Publish Data…”
Having said that, please feel free to read the Outside Online article linked above for some background on the research groups involved and their reputations within the field.
Ran in a pair of Vaporfly 4% yesterday at a 10k race. Gotta say I think the research was spot on based on both the results I got and also how recovery is going after the race.
Recent background is I ran this race last year (not as trained) and ran a 38:48 and then had a 10K PR last December with a 37:38 ( 100 day run challenge in effect).
So this Sunday’s race I ran 36:47 10K, a PR by 51 Seconds and 2 minutes faster than last years race. Super fun race with a stacked field ( 3 guys ran 29 minutes and a 45 age group world record was set).
These shoes definitely make you feel as if you are using less energy and helped me hold my pace throughout the race.
