Not sure what I did to offend the velo Gods, but I have been cursed recently with bikes, and now this: a series of misfortunes occurred coterminously and the like-new TriRig Omni – which was secured to the back of my car by the Kuat Transfer 2 bike rack – was launched onto the road behind me while I was driving. Naturally the bike landed drive side, taking a solid chunk of carbon off the Alpha X and all but destroying the pedal, extension shifter, brifter, rear derailleur, skewer, and saddle. The frame itself suffered no visible damage, but it’s not something that can be resold after an incident like this. And the bike isn’t even mine.
This post serves three purposes: to warn other consumer/owners of this product or products like it of this potential liability; to discuss failure points of bike racks and which solution best strikes the balance between ease of use, method of attachment, etc. and security; to solicit advice on insurance coverage protection of this and other car/bike related accidents; and most importantly, to blame the manufacturer for the failure and jeer at them. The last one is pink. Sort of.
The articulating arms of this bike rack and of others with similar mechanisms extend over the front wheel and secure the bike by the tire close to the head tube. If you’ve used this type of rack, you know that it can be tough to place this arm in the perfect position such that it doesn’t scrape up or put undue pressure on the front brake, while also placing it aft enough on the tire/wheel to lock it into the ‘base’ of the rack. I usually push this arm down very hard so that the tire actually compresses, for security, and I did that here. The rear wheel is secured by a thick plastic strap that you put around the rim.
The issues were several fold. The first is that I made the inexcusable mistake of using the Vittoria Corsa Speed tire on my 808, and the VCS shitbox tire went flat during the two hour drive. My suspicion is that a small piece of debris was picked up during my ride and a slow leak developed, which was accelerated by the pressure of the articulating arm.
Then, the flat allowed play to develop, and the small rocking to and fro put pressure on the plastic strap that secures the rear rim to its base – the plastic strap eventually gave way and totally snapped. This plastic strap is obviously a piece of crap.
The articulating arm placement exacerbated these risks. Because the Omni has a plastic cover, I placed the arm slightly out from the head tube so as not to dislodge or scratch the cover.
Had this incident occurred during the 95% of my drive that I was on the Turnpike, there would be no Omni to speak of. I was driving 20 mph 2 blocks from my house, and yet despite the speed, the garbage city streets shook the bike loose. I had the windows down, and it sounded like a crane dropping a heap of scrap metal from three stories high. It took me half a block to consider that the sound could be Omni. That feeling when I looked back and saw only one bike…the worst.
Any system has failure points, and any system that involves consumers likely has drastically higher failure risk. But what in the actual fuck? These are $10,000 bikes I’m carrying around through different terrain in all kinds of conditions. This particular system cannot have a failure. It just can’t. So which system has the least potential for failure with external carriage of bikes? Is the solution a 1up-usa rack…or is it a 1up USA rack? Sprinter van?
What about insurance? Sundays insurance and veloinsurance are outrageously expensive, with rates no actuary could justify. My homeowners has a low cap on sports equipment, but that’s one insurer: does anyone know which homeowners policy allows very high caps for sports equipment? Is there some way to get a rider on car insurance that protects against accessory goods? My car insurer is my homeowners insurer, so they kicked me right to the curb.
What about Kuat? Do they deserve any blame here, and if so, should I seek damages in recompense? I honestly don’t think so, but I’m sure not buying one of their racks, or any racks like this, in the future. Right now I’m still using this rack but wrapping a tube around the rear and smashing the front brake/brake cover. Better dinged than lost
