Wondering if they will be compatible with other bar systems? I’d love to pick these up for my BMC timemachine, but that runs off profile design bolt spacing standards.
They sure look nice, but they don’t look like they would work with a position that has narrow elbows. I was thinking that you could maybe switch out the left and right sides but the curve of the area under the forearm would be very wrong.
Their regular cups swivel in and out, and the TFA bar has a lot of width adjustment. I imagine the TFE will have similar levels of adjustment as the standard cups. What about these bars suggests it won’t work well with a typical narrow position? I won’t see any reason for that to be the case
These actually can be used with the TFA base bar, the non integrated stem version (si013) and clip-on systems that use a 31.8mm bar standard. Check out the video here @:49 sec into the video https://youtu.be/1JAkr-Z7_M8
$400 price tag seems to be for just the extensions. If by “silly†you mean “silly badâ€, I would tend to agree.
Have you seen the market for “just extensions”?
yup. paying $400 for extensions (let alone more than that) is silly. Now, I tried out Tririg Scoops and they were super comfy–I can totally get on board with a $160 product that supports and actually touches my forearms. But these extensions that purportedly cup my entire arm–but are not big enough to even actually fit it–and “support” an area of my arm doesn’t need any support–i.e., between my forearm and my hands-- is silly at $400 and ridonculous at some of the prices over in the UK.
Then undercutting the current market, in some cases by thousands of dollars, means it’s a silly good price for the market. I won’t try and convince you if it is a good value or not, that’s not the point. The point is for the product and market place it is in competing in it undercuts the best bang for the buck by a fair margin. i.e. silly
I also don’t get this discussion about support. I don’t want or need any more support than I currently can get by any “normal” pad/cup design. My desire in a product like the TFEs is to get the extensions out of the wind and hug my arms to have the least impact on my CdA. Obviously this is not a need and merely a want.
That’s fine if that’s where you are at. I’m presumably bigger than you, have bad shoulders. The additional support provided by TriRig Scoops was probably the best upgrade my Tri bike has ever seen. For me, I will go a lot faster by being more comfy than by theoretically lowering my CdA through arm-hugging position that I could never achieve anyways. The average triathlete is far more like me than you.
To be fair, Speedbar-type extensions are generally designed for FOP looking for extra speed and not the “average” triathlete who has comfort issues.
